Connect my supernait to oppo sonica dac
Posted by: Richard walker on 11 December 2017
Hi. Newby question again.... what is the best way to connect my new Supernait 2 with an oppo sonica DAC. The DAC has RCA and also balanced XLR inputs.
My budget would be 100 GBP.
Thanks in advance
Posted on: 12 December 2017 by james n
An RCA to DIN cable should do the job. Ignore the balanced outputs for this application.
As to cables, something from Chord etc will be suitable. Make sure you specify that it's RCA output to (Naim) DIN input to get the right cable wiring configuration at the DIN end.
Posted on: 12 December 2017 by Japtimscarlet
You might struggle to get chord for £100 budget...
But other good makes about
