Chord Hugo 1 bargain used prices.
Posted by: Bob the Builder on 13 December 2017
 On the used market the hugely celebrated Chord Hugo 1 now sells for an average £650.  So if you are looking to try one now is the time at less than 50% of the rrp it has to be one of the bargains of the year.
Strangely the Chord 2Qute which cost only 70% of the Hugo 1 new still fetches £750.
Posted on: 13 December 2017 by Simon-in-Suffolk
I agree the Hugo 1 is still one of the best DACs out there....great bargains to be had...
Posted on: 13 December 2017 by Jonn
Big drop in market value after what three years?  Presumably the impact of a new model plus concerns over battery life and long term servicing not guaranteed to be available?
The absence of software updates to Chord DAC and Streamer technology ( apart from buying a new or updated model) is also a factor I suspect.
I suspect you will be to have the Hugos serviced for some time yet... and if you have to, changing the battery is not too challenging so I am told. With regard to software I heard that just about every last piece of memory in the Hugo was used so not much else one could do, and the algorithms have been considered optimal. Clearly if there was a bug to be fixed that would have been different...
Posted on: 13 December 2017 by Bob the Builder
I just think that those who want a Chord Hugo have one and lots of those now want a Hugo 2 and have traded in their mark 1's.
Posted on: 14 December 2017 by Mayor West
Absolute steal at £650. For some reason I don't hanker after Hugo 2 at all. Maybe I should.
Posted on: 14 December 2017 by Eloise
Jonn posted:
I know you are talking about the Hugo really, but the QBD76 and (iirc) DAC64 had (paid for) “software” upgrades over their lifetime.
Posted on: 14 December 2017 by audio1946
best thing to do is to replace the battery asap after purchase if its 3 year old  ,it will fail.
