DSD DAC V1 using Audiovana 3.1
Posted by: LikesToys on 14 December 2017
I have attached a DAC V1 to a Mac Air on OS X Sierra using USB. When I configure Audiovana to send DSD directly to the Dac V1 all I hear is hissing with the music very faint in the background. If I use PCM I hear the music fine.
To my knowledge the V1 firmware is up to date at V16. DSP Dav v0.0.52 DSP Dac Boot V1.0.0 IR Sys : 22
Audiovana picks up that DSD64 and DSD128 are supported by the dac. I configure Audiovana using DSD over PCM standard 1.0 (also tried 1.1 but no luck). All Bit Perfect tests pass.
Going from DAC V1 to Naim Supernauit 2
Any suggestions?
