Last Played on NDX does not refresh
Posted by: AudioSven on 17 December 2017
I have an NDX that gets fed from a UnitiServe.
Interestingly, on on the NDX and on the naim app the list with album 'last played' is not being refreshed.
Date and time on the UnitiServe are set to the correct values.
I now found a way to trigger a refresh:
1) switch off 'last played' in the UPnP section of the UnitiServe
2) try to retrieve last played on the NDX or the app (menue item disappears)
3) switch 'last played' back on again in the UPnP section of the UnitiServe
4) retrieve last played again on the NDX
=> then you can see that the list is retrieved and it is displayed correctly. Thus, the connection between the 2 devices is ok, the UnitiServe provides the data, it's just that the NDX seems to be too lazy to fetch when accesses by the user.
any ideas or anyone with a similar problem?
