AV2 Analogue Versatile 1 & 2 label confusion
Posted by: rackkit on 30 August 2011
I'm looking to hook up a 5.1 Bluray to my AV2 using RCA to the 4 pin DIN inputs and am little bit confused by the manual. V1 in multiple (versatile) mode on one page says it inputs front L-R and surround L-R. V2  in multiple (versatile) mode inputs centre, sub and rear L-R.
Another part of the manual describes V2 L-R as extra rears. So which is which for just rears in a 5.1 set up?
Thanks in advance,
Rack.
Posted on: 31 August 2011 by Richard Dane
Rack, when the manual refers to "rear" it means the rear effects channels on a 7.1 system.  For a 5.1 system the rear effects channels will be the "surround" channels, because the rear two channels are not used.
Posted on: 31 August 2011 by rackkit
Ah, that makes sense now.
Thanks for explaining Richard.
Rack.
Posted on: 31 August 2011 by DavidDever
The channel nomenclature was equally confusing within the pro audio realm as well, until recently–don't feel bad!
Glad it's not just me then!
