Flashing Nac 272
Posted by: sjostrom on 21 December 2017
I just received the years last upgrade, a Nac 272 bought via eBay. Unfortunately the Naim logo and display is flashing every other second. Its not loosing power, I can continue going through the menus when the display is on - its however not usable since I cant set it up. I have managed to restore factory settings, bit the problem persist. I have also tried turning it off for some time and removing and re-adding the link plug as well.
Any suggestions or is it ”just” to locate the general agent in Sweden and send it to Naim for repairs? Not the best timing either, it will be a christmas holiday without stereo.
Posted on: 21 December 2017 by Peakman
sjostrom posted:
The Logo should flash when mute is engaged.  You can un-mute from the handset but you can also mute/un-mute by touching the Naim logo and it is possible that this may be faulty.
Roger
Posted on: 21 December 2017 by David Hendon
But I don't think whether or not it's muted would affect setting it up?
Anyway I vaguely remember that you can disable mute via the 272 logo in the 272 setup (spanner key on the remote).
best
Posted on: 21 December 2017 by sjostrom
Hi, thank you for your replies! But the display is also flashing along with the logo, is that also part of the mute functionality?
Anyhow, I'll go directly to test this!
No it's not. I'm afraid it probably is a case of needing a repair.
best
Posted on: 21 December 2017 by Richard Dane
SJostrom, I've flagged this up for Phil so hopefully he'll see it and may have some ideas before he leaves for Christmas break tomorrow.
Unforunately muting/un-muting didnt help.
Great, thank you Richard!
Posted on: 21 December 2017 by nitrous
Sjostrom, any way you can plug it in to your computer (usb) and router (network cable) and try to reinstall the current software from naim website? Can’t harm it if it isn’t usable anyway, and may work is software related.
for the record the logo doesn’t flash when muted, it goes off if this option is selected in the main menu when muted.
Ahh, then Ill the this tomorrow as well Nitrous, as you say, it cant do any harm now. ????????
Posted on: 03 January 2018 by Sid
I have exactly the same issue. My 272 will be returned to the dealer tomorrow. Will update with the resolution.
Posted on: 03 January 2018 by sjostrom
Hi Sid,
mine has ben sent to the swedish agent for further transport to Naim for repairs as well.
I`m hoping it wont Take too long.
Posted on: 12 January 2018 by Sid
Hi Naim
Any update on this issue please? Looking forward to good news
Posted on: 12 January 2018 by Richard Dane
Sid, you’ll need to ask your dealer or ask Naim directly. They won’t see or answer on here.
Posted on: 12 January 2018 by sjostrom
Hi Sid,
it has arrived at the factory, so hopefully it will back home in Sweden within a few weeks. I longing for it and music now!
Posted on: 17 January 2018 by Sid
Hi Sjostrom, yes it will be good to get it back asap. I have not heard from the dealer but it only lasted 3 weeks before it packed up. Im hoping for better Naim experience going forward.
Posted on: 26 January 2018 by Sid
Collected my 272 from the wonderful people at Sevenoaks Yeovil yesterday and its great to have it back. The main circuit board was replaced.
Posted on: 26 January 2018 by sjostrom
Oh! Lucky you! I still haven't even gotten a estimated date from the Swedish agent! I hope your will work perfectly now. Happy listening!
Posted on: 26 January 2018 by Japtimscarlet
Glad you have it back ....but now you have to run it in again ...the joys of hi-fi
