Turning display lights off
Posted by: Nigel 66 on 23 December 2017
Dear Forum
I recently moved house and have packed all of my naim cardboard boxes away after setting up my system - which is sounding better than ever in its new home. I've also only kept one hand controller out (it came with the ND5 XS) as I tend to use the app for most things now.
However, when I've powered up my SuperNait 2, it's display lights are all on.
Is there a way of turning them off with ND5 controller, or do I need to dig out the SN controller?
I know this is a daft question, but if I can avoid getting the boxes out, it will save me a lot of time today.
Thanks for any help.
Nigel
Posted on: 23 December 2017 by Pcd
Nigel, I’m pretty sure you will need the SN remote my NDX remote will not switch off my 252 lights it looks like a loft visit is required.
Posted on: 23 December 2017 by Nigel 66
Thanks PCD. Thought that would be the case, and as expected the boxes are at the very far end!!!!!
Nigel
Merry Xmas and best wishes for 2018 to all as well !
Posted on: 23 December 2017 by Richard Dane
Nigel, you will need a Narcom handset to do this.
Thanks Richard. An exciting job for this afternoon then!
Merry Xmas !
