Tagging by artist surname
Posted by: Bryce Curdy on 25 December 2017
So I know how to deal with 'The', but how do I sort by surname but have the artist appear correctly on the streamer (rather than 'Bowie, David' for example)?  At present I have Artist and Album Artist set to 'Bowie, David' and use Advanced Search > Album Artist / Album as I prefer this way of handling compilations.
I'm using Asset UPnP, dBpoweramp CD Ripper, Mp3tag, a Naim Atom and the Naim app.
Posted on: 26 December 2017 by Gavin B
Put David Bowie in Artist and Album Artist, and put Bowie, David in Sort Artist and Sort Album Artist
Posted on: 26 December 2017 by jsaudio
BTW how do you handle "The", Sorry,still new at this. Asset UPnP, dBpoweramp, Yate ,Qnap NAS
thx
Posted on: 26 December 2017 by Mike-B
I just rename the "The's" in the NAS using Windows Explorer /  File View.   Beatles, The,   Moody Blues, The,  Who  Strolling Bones etc..    simpl'z
Posted on: 26 December 2017 by Eloise
Bryce Curdy posted:
Dump asset, use MinimServer.  Fill the Artist in as (e.g.) Bowie, David and then use the “reverseName” option (see http://minimserver.com/ug-libr...reverseName%20option ).  You can also automatically ignore The (and other words as you choose) in names for sorting.
Alternatively you can fill in ArtistSort (and AlbumArtistSort) for each artist.  So (e.g.) Artist: David Bowie; ArtistSort: Bowie, David.
jsaudio posted:
thx
In AssetUPnP setup, you can change setup to...
The Artist & Album Handling has 3 modes (examples using The Beetles):
Smart: this mode keeps the artist text as The Beetles, yet sorts the artist under 'B'
Value, The: places the on the end, for example Beetles, The
Leave as is: does not adjust the displayed value or sorted position
