DSD64 vs 24/96 FLAC vs Tidal
Posted by: Obsydian on 31 December 2017
Must be the holidays so listening more and went back to an old but now closed post regarding DSD.
Anyway I invested in 24bit FLAC and DSD 64 versions of Micheal Jackson Thriller and History (i have other DSD128, but all classical and not my normal thing), plus my Tidal Hifi. The former two downloaded from a well known website and added to USB.
I did some mild refresher reading purely on formats, but avoided the which sounds better opinions.
I must say the DSD64 (max I could find so not apparently equivalent to the 24bit FLAC sounds just of so natural, soundstage transends further, small details are effortless, so musical a real toe tapping joy to listen to. Real shame could not source a DSD128 version : (
Tidal HIFI came last, but at £20 a month (Thriller DSD64 was £17 alone) and the vast catalogue that compromise works for me.
Posted on: 01 January 2018 by Adam Zielinski
The Thriller (album) was recorded and mixed in an all-analogue domain.
So any DSD conversion is post, which means it does not bring anything meaningful to the table so to speak.
The best re-mastered digital version I could find is a PCM at 176 khZ / 24 bit. Matches my 1st edition Japanese vinyl quite well.
Posted on: 01 January 2018 by Simon-in-Suffolk
Adam - not so surely - if Thriller was as you say all recorded and mixed in the analogue domain - and an analogue master is produced - if that is then encoded in  Delta Sigma/DSD and not modified until decoding reconstruction time then one would get any apparent benefits of that encoding format without PCM getting in the way.
I agree if the DSD transfer was made from a PCM master then I can see little benefit other than perhaps optimising for a users particular replay system.....
Posted on: 01 January 2018 by Mike-B
End to end DSD recorded & reproduced material is as rare as hens teeth.   Multi mic, mIxing/mastering is invariably done in PCM,  simple acoustic, coral & small ensemble with little or no post production editing are about the only way to get end to end DSD,  even then it most likely has a conversion of some sort in the process.    The only people I know that are end to end DSD are Blue Coast Records,  but they freely admit there large ensemble recordings have to be in PCM.  Holland based Sound Liaison are trying hard to perfect DSD & have up to recently been recording in PCM,  they now seem to have worked out recording in DXD.    Both have some interesting reading on how recording & mixing is done.     But it has to be said listening to well recorded simple work via DSD can be very rewarding.
Posted on: 01 January 2018 by Obsydian
Interested I assumed the two were totally different and not convertible.
Might ask for a refund from the site as it sold as original DSD, but still profess it sounds so much better.
Simon-in-Suffolk posted:
Good point Simon. I was actually thinking the same - if an analogue master tape is available than capturing in any digital format is possible - PCM or DSD.
Obsydian posted:
I wouldn't go as far a claiming discounts. But at least you see now that all that glitters is not gold...
Posted on: 01 January 2018 by Eloise
I may have the history wrong... but I understood that archival transfer of (2ch) analogue Masters was one of the end goals when DSD was being developed.
Ok so got some feedback and bit of digging myself -
DSD file created by Gus Skinas from the original Sony Super Audio CD cutting masters.
Also the max FLAC is 24/96 which is what I have.
