Mu-so QB Volume Control Light
Posted by: gundo on 01 January 2018
My mu-so qb rotary volume control light started to flash slowly while playing music, what can be the reason for that?
Posted on: 01 January 2018 by blythe
The only times I've seen mine do that is when it's trying to either connect to the network (I use wireless on mine) or, when my Internet has gone down and it's unable to connect, for example, to iRadio.
Posted on: 02 January 2018 by gundo
Thank you @blythe I guess the same, it might be a connectivity issue, yet it continues playing properly. It stopped flashing after some 15 mins.
Posted on: 02 January 2018 by blythe
Depending on what source music you're playing, it might continue playing. For example, if you're listening to upnp music stored on a NAS drive, your internet going down won't pause the music.
I have a few wifi access point on the network I use and I had occasional issues where the QB would connect to a slightly less strong signal access point.
In the end, I changed the SSID of the one closest to the QB and reset it to always connect to that stronger network.
Posted on: 03 January 2018 by gundo
Thank you for reply Blythe. I will check whether it will continue or not.
