Issues using Uniti Atom as a UPnP server
Posted by: RadebeR on 04 January 2018
Hi -- I have a Uniti Atom, a Muso and a Muso Qb and I'm generally thrilled with all three as "players". Most of my listening is streamed from Spotify but I have a handful (and I'm gradually adding to it) of hi res albums that I have on a USB memory stick connected to the back of the Atom. I would like to use the Atom as a UPnP server so I can play those hi res albums on the Musos but my experience of the Atom as a "server" is very poor. The Atom will show up as a server in the Naim app, the track lists will appear (and everything is nicely indexed in the correct order) but, when I select a track, the relevant Muso will fire up and then play nothing. A factory reset of the Atom solves the problem so I know it can work.... but that lasts for a few hours and then it gives up again. It's not an issue with bandwidth or throughput of my network.... the atom and the muso are hooked up with ethernet and the Qb has a great wifi signal. If I use my Mac as a UPnP server then all 3 devices can pull from it with no issues at all.
Has anyone else experienced this issue or anything like it? Any bright ideas? I know the Uniti Core had plenty of issues so I'm wondering whether a few of those found their way in to the Atom's UPnP server firmware....
