Speaker upgrade????
Posted by: andyharc on 05 January 2018
Hello all
With the New Year here I am looking at upgrading my very modest Naim system.   At present I have a CD5, NAC202, NASP, Flatcap2, NAP150x. KEF Q5’s.      I think I need some better speakers.    Where should I turn to match my system.    I have like located  a set of reasonably priced Intro2’s I believe.     Would they sound better?   I know it is all relative      But I value this forums opinions.
Thanks.
Posted on: 06 January 2018 by Iver van de Zand
You might want to look for a pair of Naim Allae's. They sound wonderful !
Posted on: 06 January 2018 by joerand
andyharc posted:
I think I need some better speakers.    Where should I turn to match my system.   I know it is all relative
Indeed it's all relative. I'd say exhaust all speakers available locally for no-cost demo in your room and gain perspective from there. Speakers are 100% about room-fit and your tastes. I could tell you speaker X worked great in my room, but of what value is that to matching your room, system or expectations?
Posted on: 06 January 2018 by Adam Zielinski
Why do you think you need new speakers?
Posted on: 06 January 2018 by ChrisSU
I would consider a source upgrade, you’re running an entry level CD player into a quite capable preamp.
Posted on: 06 January 2018 by yeti42
allaes will cost you £800 from a dealer (google it) try and get a way to audition them. They’re a bit coloured but you don’t notice after a short while and they’re very enjoyable.
Posted on: 06 January 2018 by Japtimscarlet
Intros really are at the bottom of the food chain and don't always command much respect on here
Personally I would not give them floor space ..and yes I have owned them in the past...
Posted on: 06 January 2018 by Huge
Speakers are such a matter of personal taste.  Choose to match your tastes and the room in which you'll use them.  Listen to loads, short-list a few and try to get the dealer to allow a home demo.
Then pick the ones you like best.
Posted on: 06 January 2018 by Innocent Bystander
And consider buying secondhand d to maximise buying power.
Posted on: 06 January 2018 by andyharc
Is the CD5 considered entry level??
andyharc posted:
Within the Naim hierarchy, yes. That isn't to say that it's a poor CD player, but in terms of system matching/synergy, your amp is capable of showing off the talents of a 'better' player, maybe up to CDX2 level.
ChrisSU posted:
Interesting supposition to me - that an amp can show off a source. In my experience, the amp has much more to do with powering and showing off the speakers' capabilities. PSU's, interconnects and power cords on the source are more germane to upgrading the output of a source than is the amp.
Posted on: 07 January 2018 by S3
I’d avoid Intros 2s. I ran a pair with a CD5 and Nait 5i and found the presentation very forward and harsh at times although that may have been the amp. If you went for them I strongly suspect you’d be looking to swap out before too long. If you want Naim speakers then, as others have suggested, the Allae are a good shout but also see if you can try a pair of Kudos X2s which are wonderful and versatile speakers for the money. I don’t know what your budget is or where you are located but you should be pick up a pre-loved pair for around £750.
Dave
