Deep sleep mode works not properly
Posted by: aaj on 06 January 2018
On my naim uniti nova  works the deep sleep mode not properly
most of the time after pressing the on off button more than 3 seconds
the device switches to the standby mode.
This is the case when operating both the device and the remotecontrol
Posted on: 10 January 2018 by Bouba
Hi Aaj, I have a similar issue as well, except, my Atom will go into deep sleep mode only when pressing the stand-by button on the front panel of the unit, when using the button of the remote, it'll simply go into stand-by mode.
If I recall well, the on-line manual states "to put the Uniti Atom in to Deep Sleep Mode, press and hold the power button for 3 seconds on either the front panel or remote."
Well in my case, using the remote will not put it into sleep mode.
Do some others owners have the same issue?
Posted on: 10 January 2018 by fordy
Same on my Atom, can only get it to deep sleep from front panel stand by button on the unit. Not the remote.
Posted on: 10 January 2018 by GregWPGibbs
Yep, same with my Star
Posted on: 10 January 2018 by Filipe
fordy posted:
The Core is the same, although sometimes after reboots etc it ends up working as it should. Then it sinks back to this problem!
Phil
i don’t get it : the new range’s  manuals state and describe a whole bunch of features that are actually not available on the various units...
i do understand that any new gear/technology may have flaws or small bugs, however taking a look at the number of glitches and issues I get with my atom, also experienced by others users here on this very forum (and the list just keeps growing), I wish we were not the beta testers
