NDX error
Posted by: Lennardo on 08 January 2018
Good morning
Inexplicably my NDX has 'error use naim app' then it skips tracks rather than playing.
There's been no network changes - I've run command arp -a and the NDX has an IP address assigned. It's hardwired.
Many resets of all components has not improved things - does anyone please have any ideas?
Many thanks
Posted on: 09 January 2018 by Adam Zielinski
Can you please list the following:
* Which UPnP server software are you using
* Where do you store your music and in what format?
* Basic network configuration
* IP assignment: fixed or dynamic and which component handles that
Posted on: 09 January 2018 by Mike-B
I had the same problem a while back when I was 'experimenting' with my new broadband hub.  Because I was in 'experimenting' mode I solved it quickly by going back to defaults & did not determine what the problem was but suspect an IP or DNS address error.       In my case I reverted everything back to all DHCP,   then powered cycled the whole system & restarted each component sequentially  (router, NAS, NDX, iPad)
Posted on: 09 January 2018 by ChrisSU
Beachcomber posted:
So all traffic between the PC and the NDX is through the switch, and does not go down the Ethernet over mains.
That doesn't necessarily mean that the NDX is immune from the mush your EOM is putting out. This may not be relevant to your current issue, but I would consider eliminating the EOM from your setup, at least temporarily, to see if it affects sound quality.
Beachcomber posted:
I'm confused! Are you Lennardo?
Posted on: 09 January 2018 by Beachcomber
Oops - sorry - I only picked up the question and ;thought it was a general enquiry.  Forget my message.
Posted on: 10 January 2018 by Lennardo
ChrisSU posted:
Beachcomber posted:
Beachcomber's setup was similar to mine so I did not intervene. In fact it was so close I contacted my pet hacker to ascertain they weren't lurking on my network, ensuring I stay within my Grime allowance. They have a new puppy so they assured me they're too busy.
Mike-B posted:
I've reset everything on the network - it's all DHCP. The NDX shows with an IP address assigned, but with the error statement on the front panel - no change basically. The fault came from nowhere as there's been no changes to the setup for some time.
Posted on: 10 January 2018 by David Hendon
If it were me, having tried all the obvious network things as above, I would do a factory reset on the NDX.
best
David Hendon posted:
best
That is a good suggestion - but it didn't work. I've finally identified that the Tidal password was updated to include special characters. For whatever reason Naim does not support those. An update to an alphanumeric phrase and we're back in business.......
Thanks everyone for their help.
The next firmware upgrade for NDX will fix that Tidal password non-alpha character issue I believe.
best
A bit late for several hours of power-cycling and head scratching......
