Just pressed the GO button for DR on 300
Posted by: antony d on 08 January 2018
asked my dealer this morning to get my 300 serviced and moreover DR - changed earlier this year from 200 to 300 which was a real upgrade, prob the biggest step up for me since i began the journey some 17 years ago - 202 to 282 was very good and certainly added a lot more detail but the 300 was a real WOW moment when added
rest of system LP12, NDX,282,HCDR, Fraim - ideally if funds allow this year 555 for the NDX or SC for 282
Posted on: 08 January 2018 by Harry
Lovely amp the 300. So musical and full of detail and subtle poise. Not that it can't rock on demand. From what I've heard the DR allows it to sound even more 300 like.
Posted on: 08 January 2018 by MDS
Good call, Anthony. You won't regret it. I used a 300DR with a 282 for a while and it works a treat, though I used a SCDR on the 282.
Posted on: 08 January 2018 by Matty.s
ANTHONY D,
A couple of questions if I may as my system is similar and I have a upgrade in mind.
Did you try a 250dr before deciding on the 300.?.The 250 dr was my next potential upgrade.
Have you tried a psu on the ndx or a supercap on the 282.? I ask a super-cap on my 282 maybe a better upgrade than moving from my 200 to 250dr.
I couldn't unfortunately justify a 555 but I purchased a xps2 dr and was very,very happy with what it done for my ndx.
Posted on: 08 January 2018 by AndrewG
Matty.S
I see you are relatively new to this forum. it would be very helpful if you could provide details of your current system in your profile. In that way you might benefit from the huge amount of knowledge available on this forum. Many members have wide experience of the potential upgrades you are thinking about.
Posted on: 08 January 2018 by rjstaines
Whoa... hold on there.  Let's get things in perspective, please... SC for 282 has to be the higher priority.  The 555 on an NDX will be good, but nowhere near what an upgraded 282 can give you,
BTW, I'm thinking hard but as far as I can recall my 300 didn't have a 'Go' button... have they changed things?
The logo goes in on a spring. Very difficult to get it to work but with hours of practice it is possible.
Posted on: 08 January 2018 by Huge
rjstaines posted:
<snip>
It's the small button on the right hand side of the front panel of the 300PS.
If you don't push it in, nothing comes out of the speakers!
AndrewG posted:
Matty.S
Ok,will do AndrewG,thanks.
To get the ball rolling.
ndx - xps2 dr - 282 - hicap dr - napsc - 200 - bowers + Wilkins pm1's
Posted on: 08 January 2018 by KRM
The DR upgrade on the 300 is a wonderful thing. I did it before the Supercap powering my 252 (ordered before Xmas) and the 555 on my NDX (perhaps in 2019). You will love it.
I went in that order because I bought my 300 just before the pre-DR discount, which left a bit racked off. However, I don’t think the order is that important as it’s all good.
Keith
Posted on: 08 January 2018 by ryder.
rjstaines posted:
I can echo this sentiment. No doubt the NAC 282 and Hicap DR form a well balanced system but you've got to get those two outputs of the 282 connected to realise its full potential.
Posted on: 09 January 2018 by antony d
Matty.s posted:
ANTHONY D,
Mattt S
spent a day on demo's with my dealer going through all the options early last year to get a plan and budget in place, i can't praise them enough for the advise and guidence  given - Cymbiosis in L'ster used them for over 15 years
my system then was NDX/282/HCDR/200 with no Fraim - also use an LP12 the split is about 80% NDX
so we spent the morning on various combinations to improve the system in stages to help me with a plan & budget tried lot's of combo's - inc XPSDR, the best set up then was NDX/555/282/HCDR/250DR
we agreed at the end of the day plan way
  1. Fraim - straight away
  2. 250DR - hopefully in 2017
  3. 555 for NDX - wish list
  4. upgrade HCDR to SC for 282  - sometime in futre
added the Fraim in early spring - NOT at all dispointed with the increase on the whole system
I then contacted by dealer again in late summer for an ex demo 250DR, they had just taken in SH 300 non DR from 2010 - no contest, grabbed the 300 and its off at the end of this month for DR and service
just love the 300 and what it add's to the system
Posted on: 09 January 2018 by Gazza
I have the dr version, I love its extra scale and dynamics.......over a nap250 dr, do enjoy yourself, the wait will be worth it.
Posted on: 09 January 2018 by Bryce Curdy
antony d posted:
Do Naim provide a service as part of the DR upgrade?
Posted on: 09 January 2018 by Noogle
@Bryce  You can have a service done at the same time at extra cost
Noogle posted:
Thanks Noogle.  Is there much left to service after the DR upgrade?
I think they replace the electrolytic power capacitors and also fit new output transistors so they are the same as if you bought a new DR model off the shelf.
Posted on: 26 January 2018 by antony d
boxes are ready, taking the 300 in the morning to my dealer,  will report back going to listen to a few favorite tracks this evening so I can play when I get the 300DR back to make a comparason on DR -
Posted on: 26 January 2018 by NFG
antony d posted:
That seems a rather rapid turnaround, but hope it goes well.
Posted on: 27 January 2018 by Chris Dolan
Antony - you will absolutely love it. My DR upgrade and service on the NAP300/300PS is around a year in now - wonderful
Posted on: 09 February 2018 by antony d
had a call from my dealer yesterday 300 now DR & serviced has been returned from Salisbury, impressive turn around dealer sent it to NAIM on 29th Jan - arrived back 8th Feb
can't wait to get it back in to system might have a POETS afternoon???? and go and get it
Posted on: 09 February 2018 by MDS
Good news, Anthony. As you know, the 300DR will need to time to warm-up and run in again, so will take time to show the true benefit of your service and DR upgrade. Will look forward to you reports.
M
Posted on: 09 February 2018 by Claus-Thoegersen
antony d posted:
Nice to see that things can go fast. Maybe it is better just to send in one unit. For my dr 555 252 and Snaxo it took about 8 weeks, but that includes Christmas. It seems that Snaxo took a long time to recap.
Claus
Posted on: 09 February 2018 by ChrisSU
antony d posted:
POETS
First time I've heard that expression for years! In a previous life working in an office in central London, it was used quite regularly.
Posted on: 09 February 2018 by NFG
ChrisSU posted:
antony d posted:
POETS
Also in the RN
Hope your DR'd 300 sounds fab AD.
Posted on: 09 February 2018 by Huge
Yes, we also had POETS day in the Scientific Civil Service.
