Sonos into NDX via digital - what am I sacrificing?
Posted by: Maughan on 09 January 2018
Hello all.
I have recently acquired an NDX to replace my Sonos ZP90 (aka Connect) as my streamer.
As an aside...  Whilst I am pleased with the NDX, and I can hear improvements, I would not say that the difference is night and day.  Of course, at this level of kit, I recognise that I am in the realm of massively diminishing returns, and even room and cable conditions may make as much difference as a change of hardware.  But maybe that is a separate debate - I have a different question today.
My understanding is that (put very simply) a streamer does three things: 1) collect and tee up the required file from the NAS, 2) convert the digital information into an analogue signal and then 3) send that analogue signal to the pre-amp.  Each step involves certain electronic and technical wizardry, and there are varying degrees of quality of components available to perform each step - hence why a £3.5k NDX is theoretically better than a £500 Sonos.
If I were to run my Sonos into the NDX (via either optical or coaxial), am I correct in thinking that I am still retaining all of the superior processing abilities of the NDX in relation to steps #2 and #3?  Assuming I am thereby still using the Sonos electronics to perform just step #1, what compromises are supposedly being introduced in that process?  Jitter?  Anything else?
As always, the best (and perhaps only worthwhile) test is for me to make the connections and listen for myself, which I will do.  But in the meantime, it is of course always interesting to hear other forumites' views!
Thanks,
Matt
Posted on: 09 January 2018 by ChrisSU
As you are suggesting a digital connection from Sonos to NDX, step 2 will be carried out by the DAC in the NDX, not the Sonos.
Posted on: 09 January 2018 by Mike-B
I know of someone who has added a quality HR capable (not Naim) streamer amp & speakers to his Sonos.   The new setup is in his living/listening room & the various Sonos bits are now kitchen & bedroom.   He connects the Sonos to the streamer to enable multi-room music.    For best SQ the streamer is ethernet connected (via router) to his ripper/NAS box to which he is now adding 24-bit albums that the Sonos cannot play.
Posted on: 09 January 2018 by trickydickie
I'm surprised the difference wasn't significant.  I have compared a Sonos (ZP80) analogue output to NDX and the difference was considerable.
The difference (albeit less so) still exists when feeding the NDX with the Sonos via a digital input on the NDX.  I found the sound to be lifeless and not engaging.  I kept my Sonos for a while hoping to use lossless streaming services but the drop in quality was too much and I sold my Sonos system, replacing the other rooms with Muso QB's.
Just to check, are you transcoding FLAC to WAV as this makes a difference with the NDX?  Also I assume that the files are lossless?
If you really want to keep the Sonos as a digital source you may wish to consider other DAC solutions, maybe the NDAC or Chord products.  You will lose the ability to play studio masters and DSD though.
You might first want to establish that your Naim system is performing as it should. As you climb the upgrade ladder, system setup becomes increasingly important, and a decent rack, careful cable dressing, mains supply quality and network setup can make all the difference. Maybe worth getting your dealer involved too - did they do the setup for you?
Posted on: 09 January 2018 by Mattnbarns
To answer your question yes you gain the NDX superior processing (2 and 3 in your description).  The digital out in the sonos is supposed to be a bit jittery (there is loads of conflicting info as to whether or not this is audible on the net) but the NDX DAC should remove this as I understand it buffers and re-clocks the signal so this should be moot.  Personally I suspect that when set up right (fixed volume output, no compression etc etc) the sonos into the digital side of the NDX will be pretty close to the bare NDX but others will be along to tell you different.  I struggle sometimes to tell the difference with digital sources so they may well be right.
As ever, give it a try and see what you think.  You should not need a really expensive digital connector to test the theory and in then end the only persons view that really matters is your own.
It'll be interesting to hear your findings.
Good luck.
Posted on: 09 January 2018 by NickSeattle
I ran my Sonos Connect into the Naim DAC/555, alongside the NDX.  The hope was to keep Sonos for Deezer.  IME, even Spotify through the NDX/nDAC sounds better than my own lossless rips through Sonos/nDAC.
There are popular digital retrofits for Sonos that evidently lift performance.  I have not been sufficiently motivated to get one.  Abandoned Sonos in the end.
Nick
Posted on: 09 January 2018 by Maughan67
Thanks for all your helpful and interesting responses.
Just to answer a few points that were raised:
  • All my streamed files are FLAC, ripped to my NAS using dbPoweramp
  • All my network connections are by Ethernet - except that my experiments with various upnp servers (Asset and Minimserver) currently necessitate them being installed on my wireless laptop (as my current 7-year-old NAS only runs Twonky), so there's a bit of wireless network traffic for the NDX when using the Naim app
  • My main reason for wanting to try Sonos into the NDX via digital is to enable me to continue to have the benefit of the Sonos interface. I am hugely unimpressed with the Naim app (at best, it's functional)
  • I'm confident that my system is all connected correctly. I'm also certain that my cable arrangements are a mess, but (perhaps bar a little bit of minor rearrangement which I keep meaning to do) that's just the way it has to be with my storage/rack set-up
  • I bought the NDX new from my local Naim dealer but no offer of any home visit to do a once-over. Do you think I should ask? Is it something Naim  expects dealers to do, or would it be a huge favour?
Regardless of all that, I have now connected the Sonos to the NDX via optical.
I like it, a lot. My experiment is only an hour old (and I'll do a lot more comparing at the weekend), but it's hard to tell any difference to the NDX running via Asset (ie without the Sonos), including when Asset is transcoding to WAV on the fly. Both are brilliantly clear, crisp, exciting, accurate, revealing, with fantastic bass and vocals.
And the even better thing is, I have also been comparing it all to the bare Sonos connected straight into my 202, ie my system before the NDX. I hadn't previously done any direct A/B comparison but, contrary to my original post, the NDX is clearly much better (using either of the feeds under discussion). Which is a very pleasing finding!
So I'm pretty happy at the moment.
Thanks again.
Matt
Glad to hear you’re happy. An all round great result I’d say.
Cheers, Matt.
Try a test:   save a few WAV files to a USB thumb drive and plug it into the front of the NDX.  This is the reliable benchmark for sound quality.
If UPnP into the NDX is not equally good as WAV on USB, there are a number of aspects that can be tweaked and tuned — many more variables on a network than when using USB thumb drive, but they can be managed.
USB is also the surest way to know if you hear any difference in the various lossless file formats.  After trying them all, I settled on AIFF.  Not everybody agrees, so best to do your own test.
Nick
Maughan67 posted:
I would absolutely expect your dealer to be willing and able to come to you and check out your system. If they are any good, and want your long term loyalty as a customer, they should want to keep you happy, and ensure that you have confidence that you're getting the best from your system. My dealer would certainly be happy to do this.
Maughan67 posted:
If you prefer to use the Sonos and it's app, I think the NDX is the wrong product for you - you might find that you get better sound quality for less money by replacing it with a good DAC with an optical or coax input.
Posted on: 10 January 2018 by endlessnessism
I like Naim DACs and amps very much but I haven't yet found a Naim streamer that is good for me.
I had an HDX for a while but I found the sound was better if I used an external DAC rather than the internal one. Also, I didn't like the way the HDX tagged my ripped CDs and it was better to rip them on a laptop with dBPoweramp. I subscribe to Qobuz and Naim don't support this so I needed to attach another streamer to give me access. Why keep an HDX when I was using other products to fulfil its functions? I didn't, and I think I'd have the same issues with the later Naim streaming products.
I think the HDX also had an issue in that, if you used it as a server for a multi-room system, all the rooms other than the main one were down-sampled to lossy. Maybe that has since been cured.
If Naim produced a streamer that was only a streamer (no on-board DAC or amp) and you could simply connect it to an existing system, and that gave access to a wider range of streaming services including Qobuz, I'd be interested.
These days I use Bluesound streamers into Naim DACs and amps. It's a multi-room system and it plays everything up to 24/192 and sounds great. I can happily stream Qobuz at 24/96 which is their highest offering. The only thing missing is IP control over the Naim amps so that you can take a direct feed from the streamers and control volume via the amps.
I also have some Simple Audio streamers which sound as good as the Bluesound ones but production was stopped a couple of years ago and the control system requires a few workarounds so they're probably not a long-term solution.
Posted on: 10 January 2018 by audio1946
hardly used the ndx has a full player only use it as a expensive   transport,any my other route is   the aries mini through my dac,  cant really tell them apart.  iam thinking the sonos digital interface is flawed
Posted on: 10 January 2018 by Simon-in-Suffolk
Hi, I used to run this setup.. Sonos into NDX. It works very well, however the class of transport from the Sonos is ultimately the limiting factor and as a consequence there is more digital noise which you will notice as a loss of detail, presence and relative realism and presence... therefore if you have a quality Hi-Fi system, then ultimately you will be selling yourself short... but fine for background music and web radio.
Posted on: 10 January 2018 by Kevin Richardson
Simon-in-Suffolk posted:
I discovered that my system sounded a bit worse when I had a Connect running into my NDX. I believe it was having some kind of negative impact on the electricity since it was plugged into the same power strip as my other components.
Posted on: 11 January 2018 by Mattnbarns
Simon,
Exactly what is digital noise?  Electrical noise can be eliminated by using an optical connection 'twixt sonos and NDX. Please note I am not trying to start an argument here - your knowledge of these things far surpasses mine - rather trying to better understand what the transport issues are.
Matt
