Update opinions please.
Posted by: Cliffh on 17 January 2018
For the last 20 years or so, my system has been CD3 - NAC 102 - NAP 180 into Proac Response 2.5s.  I also have a Manticore Mantra turntable with an AT 150MLX cartridge feeding a Graham Slee Communicator phono amp.  It all sits on an Audiophile Base rack.  As you can see, I don't tinker much.
About 8 months ago, my DAB/FM tuner died and I decided to drag myself into the 21st century by replacing it with a streamer.  A quick visit to the Naim shop and, 10 minutes later, I was sent on my way with a ND5XS.  My wife was somewhat horrified at the cost, but my argument that our other Naim gear had served us well for years, so was money well spent, broke her resistance.  It didn't take long to discover that CDs ripped and played through the ND5XS sounded better than CDs played on the CD3.  I guess DACs have come on a bit in the past few decades.  I'm now copying all my CDs to Asset on a spare Windows 10 PC.
This experience has reignited a yearning for a bit of an update to the system.  I've recently seen a NAC 252 / Supercap for a good price and think I've managed to persuade the wife that, if it's clearly better than the NAC 102 we can keep it and, if it's not I can sell it again for the same price.  But the NAP 180 would have to stay.  I know a 250 or 300 DR is the usual partner for a 252 but, even if I could afford one, I probably couldn't afford the divorce proceedings that would follow.
Would such a system be hopelessly ill-balanced?  Would I be better off replacing the 102/180 with a Supernait 2, for instance?  Should I have replaced the whole lot with a Uniti Atom or Star instead of buying the ND5XS in the first place?
All suggestions gratefully received.
Posted on: 17 January 2018 by hungryhalibut
There is no point pondering on what you should have done, because you have done what you have done. You need to have a good think about where you want to take the system. If you get the 252 you will find that the ND5 isn’t up to the task and you’ll need to change it. Do you want to go there, as well as getting a better power amp?
One option is to get the Supernait and then swap the ND5 for an NDX, or swap the ND5 and 102 for a 272, and later swap the 180 for a 250 DR. Buying things because they are a ‘good price’ is rarely wise. Work out where you want to go, and how much you want to spend.
Posted on: 17 January 2018 by blythe
I think that the 252 will outshine the ND5 - with a better front end, the 252 will show a great improvement but I'm not sure how it much it will reveal the shortcomings (relatively) of the ND5...
It sounds as though you don't wish to spend bucket loads (to keep SWMBO happy) so look for a balanced system. The Supernait might just be the ticket.
Lastly, if the 252 is quite aged, it might benefit from a service which will suddenly make the bargain price look less of a bargain...
Posted on: 17 January 2018 by Innocent Bystander
Whilst it can be bettered, the ND5XS is not a bad player - indeed it was my own introduction to streaming, and I enjoyed it while I had it. It is worth noting that if at present the preamp is thevlimiting factor, and upgrading it then makes the ND5XS  the limiting factor, as others suggest, that will still have been an improvement over the present system.
However, I suggest you think about it in the round, considering whether this is a one-shot rejigging of the system to then remain static for many years (hopefully), or if you have any intent/expectation/likelihood of getting onto an ongoing upgrade path. The answer is key to deciding what is the best thing to do now within available budget. And if the answer to that is tbat one of the all-in-one Uniti models is best, or a different streamer of any description, then I’m sure that at well under a year your dealer would give a decent trade-in on the ND5XS - and the relatively small loss you’d take on it would not be something to fret over as, after all, you’ve had 9 months of enjoyment out of it and discovered the joys of streaming, just as I did.
Can I suggest considering this question then coming back here with your answer, together with some indication of budget below the divorce threshold,, when people can provide more focussed ways of soending it.
Posted on: 17 January 2018 by Perol
Yeah, perhaps you should have replaced it all with a Star and you can still do it
The 180 is fine, just get it serviced
Posted on: 17 January 2018 by Pev
If I were you I would compare the ND5 and  Supernait2 with the Nova bearing in mind the trade in values of your existing kit. I would guess that either would better your current set up.
Posted on: 17 January 2018 by Popeye
I would just like to state that I now use a NDX/Supernait2 and had a Nova before hand and the NDX/Supernait2 is in a different league to the Nova!
Posted on: 17 January 2018 by ChrisSU
Cliffh posted:
.....10 minutes later....
That seems like a rushed decision! I would go back to your dealer and ask them to help you choose a complete, balanced system that matches your needs. I would expect that to take a great deal longer than 10 minutes.
Alternatively, just be happy with the improvement you now have. If the 102/180 is 20 years old, time for a recap soon, which should bring a further improvement. As other posters have said above - you should upgrade the source as well to give a balanced system, which means an NDX, possibly with an XPS, to do justice to a 252.
Posted on: 17 January 2018 by William
The ND5 XS was also my first streamer and gave me years of enjoyment. The Naim app was a new and exciting way to browse and play music. I paired it initially with a Quad 303 and later a Nait XS2, laterally with a Hicap DR power supply. When I traded my ND5 in for an NDX this was a big step up in sound quality. It wasn’t long before I got restless again and started looking at separates and ended up with a beautiful 252/SC DR and 300 DR. At that point I traded in my NDX, XS2 and HC DR.
Here are a few truths I learnt during all this (and mostly from reading the forum):
1. The best control app today is Roon.
2. The best amps are Naim separates.
3. Naim’s streamers are good but outdated and very expensive because you have to add a power supply to get the most from them.
4. If you are prepared to invest your time learning about new products you can find a high-end streamer for about €120 (yes, one hundred and twenty) and a good DAC for about €350 used (or a very good one for 1K).
Following the advice on the forum, I invested several thousand € in a streamer/DAC that I believe matches the best that Naim can offer.
I invested the money freed up by selling the NDX in even better Naim amplification.
My other half supported me all the way because she could hear the difference and liked the results!
Will you be happy with a nice balanced system? If so by all means NDX/SN2 or 272 as HH suggested.
Or do you want the best sound your money can buy? Then trade in your ND5 for the best Naim pre/power you can afford (that doesn’t need servicing) and get a cheap and dirty streamer and specialized DAC.
Best of luck!
Posted on: 18 January 2018 by Cliffh
Thanks everyone for your comments.  It confirms what I had suspected;  that a 252 would be wasted unless I embarked on a major upgrade of everything else in the system - and that just ain't gonna happen.
As for the stuff I did buy, I told the salesman I wanted to buy a streamer.  He asked what other kit I had and, when I told him, must have thought "Aha - a man who buys entry level Naim stuff.  An ND5's just the thing."  I don't recall him suggesting alternatives, such as trading in the 102 for a 272.  Maybe he saw my wife's face when the price of the ND5 was mentioned and decided not to go there.
Most likely, I'll do nothing for the time being.  I've enjoyed listening to this setup for years and I'll continue to do so.  But a service for the old pre/power is on the cards.
Thanks once again for your help.
Posted on: 18 January 2018 by NickSeattle
It sounds to me like the ND5XS was a good choice, and you are enjoying it into a system you like.  Good place to be.  And the work you do now ripping won’t be wasted if  you make changes someday.
Sometimes a “better” pre will lift all boats, more than show off source defects; sometimes it will do both. You can never predict reliably if you will like or dislike the results.
After your next sceduled service, your 102 will be “better”.
Nick
Posted on: 18 January 2018 by seakayaker
......I think you will find quite a few members running a NDX / SuperNait2 combination and are enjoying it quite a bit. You may want to consider trading in your ND5XS/CD3/NAC 102/NAP 180 towards the NDX/SN2. You could see if the trade value of your gear gets you close enough to consider the move.
Since you have a local NAIM dealer perhaps you could ask for a home demo.
Best of luck with your decision.
