Can I run a Nac 52 and a Nac 82 on a Supercap at the same time?
Posted by: The Fat Cat on 20 January 2018
Never thought about it before, but tonight we want to make a test audition of both pre-amplifiers. If it works this would reduce the cable hassle significantly. On the other side: I don’t want my Supercap go up in smoke.
Thanks for your suggestions. Highly appreciated.
FC
Posted on: 20 January 2018 by The Strat (Fender)
I’m pretty certain no.   Mr Dane?
Posted on: 20 January 2018 by Richard Dane
No, one at a time only otherwise you will cause damage.
It's best to audition one at a time anyway.  You can't tell anything meaningful by quick back and forth switching.
Posted on: 20 January 2018 by The Fat Cat
Thanks a lot. Saved us from trouble.
FC
Posted on: 21 January 2018 by Ron Toolsie
I accidentally once booked up both a 52 and a 112 to the same Supercap using one of the DIN5 power outlets for the latter- and then using the 112 into some 135.....huge distortion that made me shut it down immediately. Having both preamps draw from common regulator boards obviously placed great stress on the regulators that not only sounded horrible...it could have resulted in a puff of smoke and a hefty repair bill. On the other hand...............
Posted on: 21 March 2018 by johnnyf
I think you can. The original use of the powered socket on the 52 is so that you could run a second pre amp. You just run a 5 pin snail fromsocket 2 to the pre amp. In the early days I would run a 32.5 off the powered input to give me 3 phono inputs.
John
Posted on: 22 March 2018 by Richard Dane
John, that’s different. You could use the AUX2 powered socket as a way to expand the number of inputs by adding say a shoe box NAC, so in theory also a NAC 82.
But that’s not what the OP intended here.
