Auralic Aries into supernait
Posted by: longmanjon on 20 January 2018
hi all,
im looking to set up a second system and have an old Aries to use, is it possible and simple enough to use the Aries with an old Supernait 1? And how can it be connected up?
thanks
Posted on: 20 January 2018 by Richard Dane
Yup, should be fine connected to the Supernait via s/pdif - either coaxial or optical TOSLINK. You just need an appropriate s/pdif cable.
Posted on: 20 January 2018 by longmanjon
Great thanks Richard I didn’t think it would be too difficult but wasn’t sure if the old nait had limitations, I’m expecting it to sound quite nice into an old pair of allaes
Posted on: 20 January 2018 by Mike-B
longmanjon posted:
.............   wasn’t sure if the old nait had limitations,
Its the new Supernait that has limitations,  no DAC (& a bunch of other stuff)   ........
Posted on: 20 January 2018 by fatcat
Mike-B posted:
longmanjon posted:
The main limitation with the supernait 2, is it doesn’t have a slab of aluminium separating the transformer, rectifiers and smoothing caps from the rest of the circuitry.
