Sonore MicroRendu set up.
Posted by: Bob the Builder on 21 January 2018
I know this is old news probably but am almost the ownwer of a used mR getting a used one to test before I buy it. Recent moves mean that my internet hub is away in the next room and will require 6 or 7m of ethernet cable so my question is will a switch be needed and well basically what is the best way that won't hurt too much financially to get the signal from the hub to the microRendu?
Posted on: 21 January 2018 by Eloise
Bob the Builder posted:
No, 7m is nothing for Ethernet.
You may feel it beneficial to connect a switch if you are relying on your ISP supplied router, but, no, it’s not needed.
Posted on: 21 January 2018 by michael17
You can just run the Ethernet cable direct fro mRu to hub. Or if you already have an Ethernet cable (say to the MacBook) running from the hub to near your system, you could buy a cheap Ethernet switch.  Connect the switch to the hub, then MacBook and microRendu to switch.  This has the added advantage (so I’ve read) of keeping the MacBook / microrendu on their own circuit, possibly reducing ‘noise’ from the hub.
Posted on: 21 January 2018 by Simon-in-Suffolk
But don’t use a cheap switch to connect to your audio equipment.. try and use a quality one if you are not going to use your ISP router switchports.. you could well be adding EM noise... see thread on SMPS tests. Yes Ethernet segments are fine up to 100 metres.. with Cat5e upto 1Gbps.
BTW for many network devices having longer Ethernet cables can be slightly beneficial in reducing Ethernet interference side effects by a small margin
Posted on: 21 January 2018 by Bob the Builder
Thanks Eloise, MIchael  and SImon would it be beneficial to run say  6m of cat5 or 6 into a switch and than 1m of a better quality cable into the mRendu. I had decided upon an SOtM 200 streamer but have had a kind offer to try before I buy the mR so will try that first.
At 6m or 1m the difference if any will be minimal... but give it a try. I suggest trying to keep the network equipment away from your audio equipment and leads if you can..
Thanks again Simon one advantage of the microRendu is it’s size easy to hide away and keep separate.
