How to duplicate Core files for use with remote site Atom?
Posted by: Braincase on 24 January 2018
I want to duplicate the full contents of my Core library onto an external drive that I can play on an Atom at another location. I tried connecting the Core backup drive to the Atom but no luck - both server and USB inputs failed to see music files.
Next option is to copy files/folders over the network to an external drive. Will that retain metadata, album covers, etc?
Thanks!
Posted on: 24 January 2018 by blythe
Copying files over the network will indeed retain metadata etc.
I do something similar with my HDX music files, to enable me to play my entire library on my Superuniti in a second home.
I do this using a NAS drive with server software installed, so once connected to the same network as my Superuniti, it plays beautifully.
Posted on: 24 January 2018 by ChrisSU
If I transfer CD rips to a USB stick and connect it to my Atom, it sees them and plays them just the same as it does the originals over UPnP.
