Uniti Atom
Posted by: David Weller on 25 January 2018
All, just upgraded from Unitiqute to Atom
Tried finding radio stations and storing on line but they don’t appear in app or on unit ?
Any ideas what I’m doing wrong ?
Posted on: 25 January 2018 by SimonPeterArnold
You need to use the Naim app to find and add any stations to the atom by adding as favourites.
Posted on: 25 January 2018 by ChrisSU
You should be able to browse and play iRadio stations without any configuration. Is your internet connection working OK? Can you stream from other web sources such as Tidal or Spotify?
