Uniti Atom power button just blinks and does not go on
Posted by: Renato.Stein on 25 January 2018
I live in Brazil and I have bought the Naim Uniti Atom while recently in Europe. I have been having a series of problems (which I can discuss in a later post) since I began using it. Still I was able to play music in a nice way. But no problem was as serious as the one now. I disconnect the player from the mains and when I reconnected it the following day the power button is just blinking and will not go on. It tries to initialize and it does not go beyond the display. I have tried everything I have read but it will not work. I have read similar posts but I did not hear of a solution. I am also very disappointed with Naim's customer service. It takes days for them to answer an email. Tomorrow I will call them in the UK. Any suggestions?
Renato
Posted on: 25 January 2018 by Richard Dane
Renato, sorry to hear. Have you tried a reboot - hold the remote close to display and press and hold power button on remote. Otherwise I would suggest calling your dealer or else Naim directly.
Posted on: 25 January 2018 by alan33
Blinking power light is the mechanism for showing a hardware fault: call service hotline and arrange for a replacement (tricky for your Europe-you-Brazil situation, I know). There is no reset or firmware solution for this state, according to the service helpline agent. Best wishes.
Regards alan
