Nac 272 via Lumin App
Posted by: t@rmac on 08 February 2018
Hi  friends,
Lumin app works fine  (openHome Render with Bubble server  ) but can't control the fast  forward/back  of the song ..............I'm obliged  to use tha Naim app for this feauture ?  Any ideas ?
thanks
Posted on: 08 February 2018 by Adam Zielinski
What features do you miss in the Naim app?
Posted on: 08 February 2018 by Huge
Adam Zielinski posted:
Reliability.
Posted on: 08 February 2018 by rightcoastants
Thanks for the tip. Will try using it as I liked the Lumin app. When I was using a Moon Mind streamer and a Linn, I preferred the  Lumin app interface over others.
Posted on: 09 February 2018 by CSI_Basel
I downloaded the Lumin app and it found my US and Nas. I can see my albums but when i try to play a track.
I get a msg: Error, please select your Lumin
whats gone wrong?
Posted on: 09 February 2018 by Eloise
CSI_Basel posted:
Whats gone wrong?
First off you it only works with a streamer such as ND*, the NAC-N or Uniti ranges.
Second, even if you have a suitable streamer, you need to run the BubbleUPnPServer somewhere on your network - this allows apps such as Lumin to see your “standard” UPnP renderer as a OpenHome renderer (OpenHome is the extension to UPnP created by Linn for their streamers but available for other manufacturers to use).
Huge posted:
Reliability.
What? You mean you miss how reliably the Naim app works and want to use a quirky, buggy alternative?   :-)
Eloise posted:
CSI_Basel posted:
Whats gone wrong?
Thanks for your answer. I have a Super Uniti.
I was just curious how it works. In the artist page, the lumin app shows a picture but in the Naim app, its only the artist name.  Maybe something for the Naim app to improve upon.
Is it possible to run a BubbleUPnPServer on a Synology Nas? If not, then I'll leave it. My Naim app works well.
Posted on: 09 February 2018 by t@rmac
For Synology
https://bubblesoftapps.com/bub...er/#synology_install
So .............forward and back during the song are disabled  ?   Could  someone try ?
Posted on: 09 February 2018 by GraemeH
CSI_Basel posted:
whats gone wrong?
For that you need the Superluminap.
CSI_Basel posted:
The Naim app only shows what the server tells it to show.  For example if I tell it to look at my Plex server (via DLNA) I get...
Naim App
Using MinimServer which looks at exactly the same files on the same server I get...
Naim App
Lumin App on the other hand completely ignores the UPnP servers browser tree, creating its own and accessing other sites to access artist images (much like Plex does to create the first view).  I tend to stick with Minimserver as it gets the job done with very flexible browsing albeit not so prettily.
