272, ATC SCM50ASLT - which way to go for the best result in Home Cinema setup?
Posted by: Tesilk on 14 February 2018
Hi everyone,
so I am thinking about the possibilities to update my system in order to have at least 5.1 setup in the room in the future.
Options are  - going active, means adding active ATC SCM20ASL speakers for rear surround, keeping 50s for the front, adding active ATC center speaker and subwoofer maybe. But it means I have to add an AV processor to 272, or even replace 272 by it.
If not, I can try to choose the passive option, and add a receiver for center and surround, keeping 272 for the front.
So I wonder if somebody had a possibility to test these options before.
What is the best one?
Posted on: 14 February 2018 by james n
I take it that you want to maintain best quality for normal 2 channel playback. If so then just keep the 272 and front setup as is and as you suggest, add an AV processor / amp. Feed the front channels from the processor through the 272 set at Unity Gain and use the processor's in built amps to drive the remaining channels. I'm sure a full active setup for the remaining channels would be fantastic but that decision is down to your budget....
Posted on: 14 February 2018 by Tesilk
james n posted:
Thanks James understood, I have already SCM20ASLs also, so i think active will be the best one.
Any suggestions for AV processor? What about AV2 or it is too old?
Posted on: 14 February 2018 by kaydee6
Go for the Marantz 8805
Tesilk posted:
james n posted:
Wow ! - that'll be some system
Posted on: 14 February 2018 by Eloise
Tesilk posted:
I'm hesitant to suggest it as Classe have recently been sold as a company (to the owners of Denon and Marantz) and so the future of the product is unknown, but if you can get one at a good price, a Classe Sigma SSP might be an option and could even possibly replace your NAC-N 272.
Posted on: 15 February 2018 by vintageaxeman
Hi Teslik, I have sent you a private message on your 'wall'. Best regards, David
Posted on: 15 February 2018 by Tesilk
Hi David, just answered.
