Album play not working
Posted by: EnataiDan on 16 February 2018
Just recently I’ve notices that when selecting an album to play it add the song but only runs the first song,  I have added tracks individually but it still only plays the first track.  Also, the app is no longer displaying where it is on the track or is the fast forward/ skip working.  I’m primarily using Tidal as my streaming source.
Seems like a major major app fail.
Suggestions?
Posted on: 16 February 2018 by French Rooster
EnataiDan posted:
Suggestions?
sometimes it appears.....i restart my nds or reinstall the app or both....and all is working again.
Posted on: 17 February 2018 by Clive B
This is an issue I face every month or two. Solution is to power off the NDS, wait a few seconds and power it up again. All will be fine again. It has not been an app issue in my case.
Posted on: 17 February 2018 by Bert Schurink
This happens very rarely and can be mitigated by switching your NDS on and off. It doesn’t seem to be an app issue.
Posted on: 17 February 2018 by EnataiDan
Thanks - will give the ndx reboot a try.
Posted on: 17 February 2018 by Adam Zielinski
Also tey rebooting your other network components, especially your router and switch if you use one.
