Slight hiss appeared
Posted by: Stephen packer on 18 February 2018
I've noticed a (very) slight hiss appear from my speakers. It's only really noticeable when I'm within (about) 1m of the speakers and is from the tweeter. Changing the volume of the preamp makes no difference to the hiss, neither does the mute button. Note that once music is playing I'm not aware of the hiss (excepting in completely silent passages.)
My system has a 282 (2xHiCap DR) feeding into a Snaxo 242 (Supercap) and then a pair of 200s into SBLs.
If I switch the Supercap off the hiss stops, if I switch the HiCaps off it doesn't and given the mute button/volume lack of influence mentioned above, I think I can forget the preamp as the source of the hiss (note I have not switched the NAPSC off in this 'test')?
The Snaxo242 is about 4 months old, the Supercap is (about) 11 years old and is (over)due a service- I had planned to have this done when I'm on holiday in the summer (and when the hifi would be unused).
Could a Supercap being overdue a service cause this sort of noise? Am I risking it developing a bigger fault if I don't get the PSU serviced pronto?
