Sotm into supernait
Posted by: longmanjon on 22 February 2018
hi all
i interested in trying out an sotm-200 into my supernait, what is the best way of connecting it up as I need to use the usb out but the supernait doesn’t have a usb, can I just use an adapter or would this degrade the sound.
i don’t want to have to buy the sotm-usb just to trial it
Posted on: 23 February 2018 by Huge
Best way to connect it is a high end USB DAC - there are lots of them, take your pick.
Posted on: 23 February 2018 by longmanjon
Thanks huge, as the supernait has an internal dac is it not better to utilise that or add another one as you suggest
Posted on: 23 February 2018 by ChrisSU
I guess you would need a USB to SPDIF converter. Never used one myself, but a number of forum members have, so I’m sure someone could chip in with a suggestion. Maybe Gustard U12?
Thanks chrissu, this is a bit outside my knowledge area with dac’s and the best options
Posted on: 23 February 2018 by james n
Are you fixed on trying the Sotm ? If not then the Auralic Aries mini would be worth looking at and has a coaxial S/PDIF output so it can connect directly to your SN.
I have an auralic Aries le already, just having a play around as I’d heard good things about the sotm
Posted on: 23 February 2018 by audio1946
james n posted:
i have the auralic mini direct to the auralic dac and it is excellent replacement to the hugo that failed twice so had to go.   A  ndx digital out is also goes to the dac  . there is only slight differences with high rez files
Posted on: 24 February 2018 by fordy
An Audiophileo USB to SPDIF converter would be excellent.
Posted on: 24 February 2018 by Bob the Builder
I have the predecessor to the sotm 200 the sms 100 and have connected to a USB Dac (Chord 2Qute) there is no reason why it will not work connected to your SN and decent USB>>Spdif converters are relatively inexpensive the Gustard mentioned above is one I used a Breeze Audio DU-U8 which can be had for less than £100 over on eBay.
The USB>>Spdif converter takes the USB signal and a decent one like the DU-U8 will clean that signal up and convert it it to a Spdif output and can then be connected to the digital in on your SN however the sotm streamers are designed to work best  with USB Dac's. A Chord 2Qute has an excellent is one such Dac that has a galvanically isolated USB in socket and because you are connecting it to a SN it's high gain wont be an issue either.
Posted on: 24 February 2018 by nbpf
longmanjon posted:
The Schiit Eitr is a relatively inexpensive USB to SPDIF converter. I have compared it to my old M2Tech hiFace Evo (powered by a TP LPS) and to a more expensive (and flexible) Mutec MC-3+ USB and decided to keep the Eitr. It works out of the box, see also https://forums.naimaudio.com/to...sb-audiobyte-hydra-z.
