Bi-wire links that work well with Super Lumina speaker cable
Posted by: crackie on 23 February 2018
Just about to get a set of SL speaker cables, however a speaker cable link set to use with my ProAc D48R speakers is proving a challenge. Currently have NACA5 with a set of Chord Signature link cables (better than the supplied pins, not saying much, a safety pin would be better than them......) .
The cost of matching SL link cables was truly frightening when I was quoted the cost. Even the Chord Sarum T link set was half the cost. I imagine the SL link set cost is to reflect the special SL plugs that I assume are quite expensive as well as a fidly hand assesmbly process for such a short cable. So not giving naim a hard time here, it is what it is, just asking for feedback with anyone here who has to use SL cables with a bi-wire speaker setup and what you are using. Or will I be hard pressed to tell the differance over a set of Chord Sgnature link set cables no matter what I try ?
Just about impossible to demo. the SL link set as they are factory order only in my area.
Peter
