Another simple question regarding a Stageline N.
Posted by: Massimo Bertola on 28 February 2018
Modern Stagelines have two rear sockets, one 5 pin DIN 240° (to get 24V from and send the signal to the AUX2 of preamps or integrates), one 4 pin DIN 240 (to use with a 4-5 pin DIN IC to take the signal to a normal line input in a pre or integrated).
If I am using an external *cap, and the necessary 4-5 Interconnect, should I take the signal from the Stageline or from the *cap (Flat, Hi, Super)? My idea is from the *cap like in any other similar configuration, and that the 4 pin, 240° DIN out was put in case an iSupply was used, but I'd love to have a clear and sure indication.
Thanks,
Max
Posted on: 28 February 2018 by james n
Both ways would work Max, but the Naim way is via the power supply so i'd go that route.
James
Posted on: 28 February 2018 by cat345
Max_B posted:
Thanks,
Max
I have tried both a few times in the past and found it hard to see a difference but I prefer the HC connection to the preamp.
Posted on: 28 February 2018 by Massimo Bertola
Thanks James, thanks Cat.
Max
Posted on: 01 March 2018 by Michael Mccullough
Correct. Connect to the preamp from the Hicap. The second socket was added to be powered from the I supply which doesn't have an output like the Hicap.
Posted on: 01 March 2018 by Massimo Bertola
Thanks.
M.
