Adding a Cd/streamer to my elderly Naim/Linn system
Posted by: GTB-Buckaroo on 01 March 2018
My system, that has served me very well since I bought it all in the late 80's now needs bringing into the 21st century.
It comprises of a LP12/Ittok/Troika; NAC62/Hi-cap/140 with a Naim FM tuner and Spendor speakers [these were recent replacements].
I have had all the kit factory serviced and upgraded here and there over the years, cartridge rebuilt,etc and to my ears, it sounds as sweet as a nut. I used to have a Marantz CD player coupled though that is playing up at times and I like some DAB radio but of course this is denied with the current FM set-up.
So, I am looking at buying a streamer with, perhaps, a CD player built in. [I would prefer a one box solution to save a little space] However, from visiting a couple of dealers recently, I had information on the new Uniti Star which seemed good, though I'd presumably require a phono-stage for my Troika, and also a piece of kit called Plato, which incorporated a MC input and a HDD to store music too, which seemed useful.
Whilst both these seemed ok, I can't help but get the feeling that neither will sound as good as what I already have plus of course, will incur a fairly hefty increase in budget. What do you think, upgrade completely or just buy a lesser brand CD/streamer unit which can connect to my current system? If the latter, any thoughts on a piece of kit to do the task?
Many thanks!
