Advice sought re. MC phono stage for Linn Krystal
Posted by: PSAN on 01 March 2018
I'm looking to get a good but not too expensive MC phono stage for my Linn Krystal (on my LP12 Akurate). I'm currently using a Rega MC Fono (which was always a temporary solution only, but quite good actually). An obvious choice would be Linn's own Uphorik, but at roughly 2600 € I find it quite expensive and ideally would like to stay under the 1500 € mark. I'm considering Trichord Dino or Trichord Diablo with the Never Connected power supply. Another candidate would be the Rega Aria. I don't think I will be able to audition the Trichords at home (at least not without some difficulty) whereas for the Rega Aria this might be possible. Ultimately, I will listen and follow my own ears, but am looking to this esteemed forum to possibly provide some experience-based input on combinations that work well (either of the above or other combinations). Many thanks in advance for any relevant insights.
Posted on: 01 March 2018 by Bob the Builder
I have had the Trichord Dino with the Never connected psu for a couple of years now and can recommend it highly it has seen me through many cartridges ranging from a Denon DL110 up to my present Dynavector 20x2L none in Krystal price bracket but a well varied selection.
Posted on: 01 March 2018 by Willy
Your budget of €1500 would get you a second hand Superline which you could power off your NAC 202 powered input.
Willy.
Posted on: 01 March 2018 by Marksnaim
Willy posted:
Willy.
Which would be good, but lead to upgrade itch, Hicap DR, Supercap DR.
Posted on: 01 March 2018 by joe9407
Marksnaim posted:
Willy posted:
Willy.
but still... this is what i would do, were i to choose something without a demo -- simply because there's such a strong track record of folks successfully using the Superline with Linn carts. synergy between cartridge and phono stage is key.
Posted on: 01 March 2018 by overprint
I run a Krystal into a Prefix powered by the pre-amp (Nac-52). Sounds lovely to these ears. I've a middling LP12 by current LP12 standards (Ekos, Lingo 1, Kore, Cirkus), may be a Radikal next but in no hurry to ditch the Prefix.
Just a thought...
Posted on: 01 March 2018 by Clive B
Yes, a Prefix has to be the obvious choice (if you can find one!). You could even get a HiCap within your budget.
Posted on: 01 March 2018 by SS250
A Prefix is what I used with my LP12, before upgrading to a Radikal/Urika 1. Used and powered a Supernait, it was excellent and very discreet. I bought mine through the excellent team at Cymbiosis and this one has just been serviced. Looks like a good value buy!
Moderated post:  Link removed. Please respect forum rules.  Thank you.
Posted on: 01 March 2018 by PSAN
Thank you all for the suggestions so far. To be clear, I'm looking for an external phono stage.
Thanks.
Posted on: 01 March 2018 by Richard Dane
I really liked the original Michell ISO - at the time it was a revelation, being reasonably resolving compared to what was around at the time, yet also good fun too. I then "upgraded" to the ISO HR and Hera - much more resolving, yet much less fun. Since then I have tried the Dino - I preferred the original ISO - and also the Tom Evans Groove which was like the ISO HR on steroids, yet no more fun, and just too cerebral for me.
So, if a Prefix is out of the running - it's a great phono stage, very engaging if a bit dark and not the most resolving - then if I were in your shoes I'd be looking for A secondhand Superline.  It will sound great straight off your NAC202, and even better with a separate dedicated PSU.  So there's scope for upgrades in the future and it could just be all the phono stage you'll ever need.
Posted on: 01 March 2018 by Geko
Why not a Naim Stageline K powered by a Hicap or, as many have said a Superline? I'm using a Krystal/Aro/Armageddon on and average spec LP12 and the Superline has allowed me to access the true performance of the Krystal. My turntable is now competing with my CD555 and I've not even optimised the loading yet! With a 576R loading it may even push it beyond!
There were a few Superline's available on that we'll know auction site recently, so your budget may be achievable?
Posted on: 01 March 2018 by R.K
Trichord Dino with LP12/Ekos/Krystal into 552/300
Dip 1 and 2
Capacitance 1nF (1000picoF). S1 on
Dip 3 and 4.
Resistance 53ohm. S2 on
Gain +64dB S3 on
Slightly different to recommended loading but works better for me.
(TriedSuperline/HiCap but no obvious improvement to me)
Posted on: 01 March 2018 by Adam Zielinski
Rega Aria or even better a Naim SuperLine - it is a spectacular phonostage.
Posted on: 01 March 2018 by Skip
I upgraded from 15 years of an AHT-Non-Signature phono stage, which was the Dan Fanny antecedent of the Lloyd Walker phono stage, to a second hand Superline.  It was a major upgrade.   It may be your last phono stage.  The power supply is always there for an upgrade option.
In a world of obscure audio variables, it is nice to have a constant, particularly in the context of a Naim or Linn system.
Posted on: 02 March 2018 by Chris Dolan
As you are using an Akurate level LP12 I would be more inclined to focus on power supply then sub-chassis
Posted on: 02 March 2018 by Bob the Builder
I still think for the money a Trichord Dino is hard to beat.   The cost of Hicaped or Supercaped Superline which is what you would end up with, in my view is an extremely overpriced piece of kit.
Posted on: 02 March 2018 by PSAN
Chris Dolan posted:
Thanks, but moving to Radikal and Keel would be a huge outlay and I'd then still have a sub-par phono stage ... (source first is a fine principle, but IMO it needs to be seen within the context of system balance - not so great to have a super source if the output is (significantly) limited further down the replay chain).
All - many thanks for the inputs, much appreciated.
Posted on: 02 March 2018 by KRM
I heard an Aria on a friend’s Akurate with Krystal and it sounded superb, admittedly in a 552/500 system.
My LP12 approximates to Akurate standard, with a Kore, Ittok, Dynavector XX-2, Armageddon. I’m using a Stageline into a 252, Supercap DR, 300 DR and it already sounds better than the NDS in many respects.
My next upgrade will probably be a Lingo 4, but I am also drawn to the Aria if it’s significantly better than the Stageline as it’s so much cheaper than the Superline and Uphorik.
Keith
