NDS Firmware 4.50
Posted by: GerryMcg on 03 March 2018
Does anyone else have this firmware update? I have just got back my NDS which was returned to Naim to repair the display, and their paperwork noted that the firmware had been updated to the above. My dealer was unaware of its availability.
Posted on: 03 March 2018 by MangoMonkey
congrats, I guess. :-)
Posted on: 03 March 2018 by David Hendon
It's been discussed on the Forum before and Naim explained that it's a service release which is required to change the display drivers because they had to change their display suppliers. So 4.5 is just 4.4 with the display drivers for the new display.
best
Posted on: 03 March 2018 by GerryMcg
Thanks David, I did try a search before posting with no results.
It may have been in the beta forum I read that most recently to be fair, but it's no secret and it's what Naim support will tell you if you ask them the same question.
best
