Uniti Star - shortcut CD eject?
Posted by: Damian B on 08 March 2018
I've tried searching for the answer to this, but can't seem to find it  - perhaps my searching powers are deteriorating these days!
I have just upgraded from a UnitiLite to a Uniti Star, and whilst I am overall delighted - I have one minor niggle.  I will likely mostly use the remote, rather than the app, and I'm wondering if there is a quick way to eject a CD from the remote?  On the Unitilite - you pressed the stop button twice - but that button doesn't exist on the Uniti Star remote.  So far, the only way to eject involves about 3 or 4 remote actions, which seems a little irritating (first world problems I know!)
Many thanks,
Damian
Posted on: 08 March 2018 by Olek_K
You have to hold play for a bit longer.
Posted on: 08 March 2018 by Damian B
Brilliant - thank you !!!
