Uniti Core - Playlist Limit?
Posted by: Spookyfoot on 10 March 2018
Hi all, I'm new to the Naim product line and have only had my Uniti Core for several weeks now. Question...I have been loading up tracks into a playlist and now it's sitting at 500 tracks and doesn't show tracks I have tried to load into the playlist beyond that number. Is this a limitation and is 500 the max you can put in a playlist?
Thanks!
Posted on: 10 March 2018 by Spookyfoot
Nevermind all, I just noticed the message that the "playlist is full". Bummer.
Posted on: 10 March 2018 by Rich 1
You can have more than one play list, not sure if the 500 apply to one playlist or the total of all play lists.
Posted on: 10 March 2018 by ChrisSU
The limit is 500 tracks per playlist, but you could still have multiple 500 track playlists.
 If you have an old Naim streamer, there is a workaround where you can queue an unlimited number of tracks using the remote, then open the app to control play. The new streaming platform no longer allows this.
