Naim Mu-So QB. Volume Dial not working
Posted by: Billy G on 12 March 2018
Just bought a Naim Mu-So QB.     Volume Dial doesn't work?    Is this a simple setting on the app or is it broken?
Posted on: 12 March 2018 by Mr Happy
There is a setting for cleaning that disables the controls on the muso. Under other settings then cleaning mode. Make sure its un ticked.
Posted on: 12 March 2018 by Billy G
Thanks for reply.   Yes I am aware of cleaning setting.   It isnt that.  thanks .
Have you tried restarting it. Unplug from mains, leave a few minutes then plug back in?
Thanks again.   Yes left unplugged all night....
In that case I would give naim a call as it sounds like its faulty.
Spoke to NAIM and yes faulty. so a return it is.   thanks .
