UnitiServe SSD: Power Supply failure? (blinking vaguely and irregularly ...)
Posted by: MichaelSch on 13 March 2018
Hi there,
Powered down my UnitiServe SSD before going one week on holiday ... came back and powered up again, but could not wake the US. The PS blinks vaguely and irregularly ...
Another thread in this forum from 2012 suggests replacing the PS, but can someone tell me what the problem may be? Is it really a PS failure? Seems to be such an everlasting part of the system that should not ever fail.
My US SSD is on 24/7 otherwise, except for holiday periods.
Michael
Posted on: 14 March 2018 by Adam Zielinski
Is there any way you could check the output voltage from the power supply? This will give you an answer if it failed.
Posted on: 14 March 2018 by Richard Dane
Michael,
have you contacted your dealer, distributor or Naim?
Posted on: 14 March 2018 by MichaelSch
Not yet, got hospitalised directly after returning from holiday - expecting to go home today though.
Just thought there might someone out there who have had similar experience and knew exactly what it could. But I will drop Phil a note ...
Adam Zielinski posted:
I know, but unfortunately I don't have a Voltmeter .... Just thought someone may have experienced the same and knew what it could be. Power supplies should be something that last forever ... maybe not.
Posted on: 14 March 2018 by David Hendon
The other thing you could try while you wait for a response from Phil could be to connect a VGA display to the VGA socket on the back of the Unitiserve. You will be able to see where it gets to in its boot up.
But if the light on the power supply itself is blinking irregularly or at all cone to that, I think this is certainly going to be a power supply failure and the good news is that getting a new one won't involve sending your US back to Salisbury.
Incidentally switched mode power supplies are only reliable if they are over-engineered or carefully designed to be completely reliable and I don't think the US power supply is either of those. Rather Naim have balanced cost and performance. Also most failures in such devices occur at switch on due to the high current surge through cold components. Anyway see what Phil says....
best
David Hendon posted:
best
As I don't see any signs of life in logo-indicator on the front panel, I suspect that it doesn't even begin the power up.
Just wrote Phil, so will wait for his reply.
(... and who has a VGA device nowadays? ... I could maybe buy an adapter for my Apple display ... I only got devices from the fruit company :-) )
I keep an old VGA display in my loft specially, although I have never had to use it on the US!
best
