Alphabetical Sorting On Muso
Posted by: Icehockeyboy on 17 March 2018
Is there a way to sort albums into alphabetical order in the music library on the Muso?
i would find it much easier to find artists/albums that I wish to play, instead of having to go from start to finish.
thanks for any help!
Posted on: 17 March 2018 by Finkfan
Hi [@mention:72948380256081881]. What is your source? If it’s tidal then just click the tidal icon on the naim app. My Music should then come up. Underneath that should be playlists, artists, albums etc. Select which you want. Tap A-Z (top right of screen) and that should sort it.  If streaming from a Nas something similar should apply. You can’t make adjustments to the Albums list on the home screen of the Naim app but I think you can remove that list if you wish.
Posted on: 17 March 2018 by ChrisSU
If you have a music collection and play it over UPnP, your server should be sending a list of albums to the streamer and app. This is normally an alphabetical list on any server I've seen. Unless you are using folder view, in which case maybe you are only seeing an (alphabetical) list of artists?
Posted on: 17 March 2018 by Icehockeyboy
Thanks for the replies, I use the first replies option, and strangely did hit the A to Z button previously, but it didn’t do what I thought it should, although it certainly does now,
Thanks again!
