Hi everyone,
Yesterday I decided to dismantle my Hi Fi system so I could do some cleaning and just check as I do (periodically) the unplugging and re-plugging of the cables with some general cable dressing and so forth... Upon doing this (out of curiosity) I decided to swap out my Hi-Line interconnect cable and try the old grey/lavender again. WOW - what an uplift in musicality - my foot was tapping harder than groundworker's boot!
This had me scratching my head as i'm sure I found the Hi-Line cable to be a significant upgrade over my lavender in 2015 when I purchased it after having one on home audition for a couple of weeks via my dealer.
Anyway, I turned the system off and re-connected my Hi-Line back in again. After I switched the system back on I now had a loud humming sound coming out of both speakers, not enough to do any damage, but even so it was there and was only with the Hi-Line plugged in as I double checked and triple checked everything!!
I have always been very careful with my Hi-Line, especially after reading about it's delicacy on here from other members, so I always gave it that extra careful handling. Anyway, after feeling a bit peeved off and again my curiosity getting the better of me, I decided to take it apart and see what the hell is going on. To my surprise it turns out that one of the 'earth' conductors had completely broken it's joint from it's pin (hence the humming). Not feeling too deflated now, I whipped out my Metcal solder iron and i remade the solder joint as well as re-assembling the plug.
I plugged the Hi-Line back into the system hoping that I had fixed the problem and hoping it would take out the lavender to boot - WOW - What a difference!!
I cannot believe it. After feeling initially impressed by the lavender after three years living with the Hi-Line, this is something else entirely, now i'm hearing what the Hi-Line is really all about - it sounds like I have a new CD player, the lavender is back in the box!
Yes, this is a happy ending but what has rattled me is that all of this time from new (three years), I think my Hi-Line was broken all along - working, but only just!
I'm not suggesting for one minute for everyone to take their cables apart or to make anyone paranoid but it just goes to show that these things can catch you out. I'm not blaming Naim because this sort of thing can so easily happen and go unnoticed even by the most highly trained and skilled pair of eyes. I have put it down to bad luck!
Now back to the music and what a cable the Hi-Line REALLY is!
Happy listening folks!
Posted on: 20 March 2018 by MDS
Credit to your investigative and soldering skills, Stephen. Must have been a very nice feeling when, after that work, the Hi-line delivered on its reputation.
I had a Hi-line for a few years and never had an issue with it, but then it was disturbed very infrequently.
Posted on: 20 March 2018 by Stephen Tate
Thanks chaps
Yep, the music is now fantastic, it's never been this good. I did check all the other conductors 'both ends' and all looked perfect, luckily it was just the one earth conductor at the source end.
My Hi-Line was ordered brand new after I gave my dealer the go ahead whilst using the their demo. I have never really mucked about with it - too expensive for me to even contemplate such actions.
I'm just so happy it's all worked out because I was feeling a bit short changed if i'm honest, especially after plugging in the lavender. Now I feel so relieved and of course proud.
The Hi-Line is a fantastic cable and has made sure the my lavender has gone back in it's box - how dare it do that to me.
Happy listening!
Full credit, Stephen, for your investigative powers and soldering skills. Result!
I fancy one myself but my lavender touches the floor so there doesn't seem any point.
Believe me Chris, it took some courage as I knew what the outcome would of been if I had messed it up taking it apart. I have the tools and I have done a lot of wiring in my time with all types of connectors so thought i'd have a look. I can't believe the uplift in performance to what I've been used to with my CDs. I mean, streaming from my laptop was more preferable but now my CD player shows that option a clean set of heels now my cable is fixed!
The lavender is good, very good and I could of left it in, but when I home demoed the Hi-Line in 2015 it was better and enough for me to justify ordering one. Looking back at things i'm now glad that my Hi-Line started humming because it has obviously revealed a fault I never knew it had in the first place and could of kept on going as is, with me none the wiser.
happy listening!
Mmm...my Hi-Line has never spontaneously fell apart, never had any of the plastic clips come apart or anything like that. In my instance it was electrical and I am putting that down to 'one that slipped through the net' on whoever assembled and tested it. I can see that it would of passed a test on a machine but passing and working properly are two different things.
Even with my headphone listening through my NAIT 5si now has an appreciable lift in performance!
Posted on: 21 March 2018 by james n
I'd agree that the Hi-Line is not the most robust of components. Most of the problems come from the 'tail' rings separating - a bit of a worry if it happens but easily fixed.
It's not really designed for frequent cable swappers and just needs a bit of care when handling. It won't fall apart on its own but take a few minutes to understand how it works, read the instructions and take it gently when plugging in or removing and all will be fine.
Posted on: 21 March 2018 by Stephen Tate
Hi,
The biggest improvement for me so far since the 'fix' is a tighter, deeper and more defined bass, a leading edge that wasn't there before (similar to the lavender) but smoother and more effortless, a quieter background and overall just a more coherent sound.
It can be a funny old world this Hi Fi malarkey...I feel much happier now that I did the upgrade in the first place. It's Just unfortunate it took all this time to reach the desired effect.
Thanks to everyone for all your kind words.
Happy listening.
Posted on: 28 March 2018 by Stephen Tate
Just WOW!
I cannot believe how good a Hi-Line cable is even through my SI series components!
The sound stage has now opened up massively with more presence in the details. The dynamics are now blisteringly wonderful with no harshness or edginess anywhere throughout the entire frequency range. Even the bass has tightened as well as gone deeper, I was not expecting anything like what i'm hearing right now or even thought this was possible from my system.
It just goes to show how important CONNECTION really is - it never ever ceases to amaze me.
Thankyou Naim for building such wonderful products!
Happy listening!
Posted on: 30 March 2018 by Stephen Tate
Thank you. I had thought that in an ideal world, a HiLine and a few Powerline Lites as you have, would complete my set. Still, it's not shabby
C.
Hi Chris,
I think the Powerline Lite cables bring a worthwhile subtle improvement (sound wise) over the stock cables. The Naim mains plugs have a real weighty wobbly quality and robust feel to them. Glad I purchased them, a no brainer really.
As for the HiLine, and in my case not as greater perceived value for money as the Powerline Lites, will bring more the higher up the chain one is with their boxes, and with my entry level set up I thought it was worth it when I auditioned it. I've just been unfortunate with mine. Do I regret it? No I do not and in any case, i'm now gunning for a CDX2!
