hiline upgrade. Is it worth?
Posted by: BobbyBlitz on 28 March 2018
Hello to all, I possess with satisfaction a system composed by Naim Dac-v1 and Supernait 2 with mac mini as source.
I would like to change the interconnection cable between V1 and SN2 with a hiline.
I currently use a RCA Neutral Cable Fascino, better than the standard 5 pin snaic 4.
Now I would like to use a HILINE, to have a further improvement over the rca connectors.
In your opinion, is it worth investing money on a 4-pin to 5 pin hiline cable?
And if Naim produces a new dac that use the 5-pin instead of the 4-pin of the current V1?
every suggestion is welcome!
Posted on: 28 March 2018 by hastings
A Hi Line will be an improvement, and if you decide to stick with Naim sources it will be worthwhile. However, many here have moved to Chord dacs as sources - the hiline no longer needed. The new streamers may change things again (we are a fickle lot). But for the moment a used Hugo seems a better purchase than a new Hi Line. If you buy a used Hiline check it carefully for damage; it is extremely fragile. Fortunately Naim seems to be rather generous with regard to repairs.
Posted on: 28 March 2018 by blythe
I was surprised by the significant upgrade swapping to a highline brought in my own system .
If possible, try one in your own system before buying.
Posted on: 28 March 2018 by joerand
I've used a 5-5 hiline on my digital (CD) side and 4-5 hiline on my analog (TT) side. No doubt I heard a different presentation with each. I considered the 5-5 a positive upgrade on digital, the 4-5 less so. Worth it? All depends on your wallet and what you're expecting to hear from your hi-fi. @blythe 's advice to try before buying is sound.
Posted on: 28 March 2018 by cdboy
I tried a HighlIne on the committee (wife) listening tester years ago. Here's A. Here's B etc. Clear preference heard and the HighLine remained.
Posted on: 29 March 2018 by Adam Zielinski
It’s one of the better u-grades for a Naim system. DIN connectors will also work much better than RCA.
Posted on: 29 March 2018 by BobbyBlitz
Surely it's a nice upgrade and in the future I think I'll always stay in Naim.
The problem is that the dac-v1 is 4 pins and I'm afraid that naim will release a dac-v2 with 5 pins in the future.
Or if I decided to switch to a streamer like nds-2 my hiline 4-5 pin would be unused. and it does not cost a little
A Naim Hiline interconnect RCA-5 Pin would be effective AS a A Naim Hiline interconnect 4 pin to 5 pin?
I think you slightly misunderstood the connectivity.
The primary functionality of a DAC V-1 is to act as a combined pre-amp and a DAC. Hence the classic 4-pin 270 degree output, for connecting directly to power-amps.
DAC V-1 has an additional feaure of acting as a source component - hence the need for a specialised 4-5 DIN, when connecting to one of NAIM’s pre-amps.
Currently I use the dac-v1 only as a dac, leaving the pre section to SN2.
Is the point HILINE 4DIN TO 5 DIN or HILINE RCA to 5pin DIN?
Will there be differences? which one should buy?
Posted on: 29 March 2018 by varyat
HiLine is a nice cable but the design of the collars is a negative- they are just too fragile.
Other "chord" manufacturers provide Din connectors
ATB,
Mark
Posted on: 29 March 2018 by MangoMonkey
Between Dac-V1 and super nait 2 - probably not.
Between ndx and sn2 - most definitely.
Posted on: 29 March 2018 by charlesphoto
Big bump in sq bewteeen my V1 and 110 with a Witch hat. Might want tp try one of those first.
Posted on: 29 March 2018 by dave4jazz
For the price of a Hiline, if you're serious about upgrading, considering a renderer, e.g. Sonore microRendu, between your MM and DAC-V1. I currently have one on trial at home. I know there are other renderer options.
Dave
