Naim Nova pre phono advices
Posted by: BeppeP on 02 April 2018
Dear All,
while I am waiting to collect my Naim Nova, I would like to ask you some advice on pre phono amp. I have a Technics SL turntable with AudioTechnica MM cartridge and I would like to connect to Naim Nova. I read few topics on the forum and seems that the only way to add a turntable is to plug into normal RCA using a pre-phono amplifier as Nova doesnt have a pre-phono in. Considering a budget up to 1000 and the fact that I would like to have some flexibility for future upgrades in the cartridge or even the turntable, which pre phono should I consider? I have noticed that there are some pre-phono that can be plugged through digital port, does it make a real difference rather using the normal RCA?
