Outdoor speaker?
Posted by: adclem on 08 April 2018
Hi folks
I have a Superuniti and QB as a small multiroom system, and I wonder if it's possible to connect an outdoor speaker; to play simultaneously. I.e is there an easy way to connect a non-Naim product!
Many thanks in Advance.
Adam
Posted on: 08 April 2018 by ChrisSU
Naim’s Multiroom system is proprietary, and will only work with other Naim streamers.
The Musos used Naim’s knowhow from developing the Bentley car audio system. Now that they make audio systems for boats, perhaps a spinoff from that will be waterproof Musos for outdoor use?!
Posted on: 08 April 2018 by blythe
Maybe you could buy an Atom, and connect that to some good outdoor speakers?
Posted on: 08 April 2018 by Eoink
blythe posted:
Probably better to look at something like a Qute 2 second hand, available for well under £1,000, and would drive efficient outdoor speakers well.
Posted on: 08 April 2018 by Bart
Or given that "hi fidelity" is rather hard to achieve on an outdoor patio anyway, think about a weatherproof bluetooth speaker, or two.
Posted on: 08 April 2018 by Eloise
Is the SuperUniti close to the patio?  How about a cheap integrated amp and DAC (or get an old AVR with built in DAC) fed from the Digital Output of the SuperUniti unto a pair of EV waterproof speakers (or similar)
In my student days, it was standard procedure at parties to put an inverted bin bag over your speakers to protect them from the inevitable beer spillages etc. The effect on sound quality wasn’t that bad. So my suggestion is a Muso in a bin liner. Bearing in mind that a non-Naim solution will not play in sync with the other streamers.
Posted on: 08 April 2018 by adclem
Thanks for all of the replies.... I should have been more specific - As Bart eluded too, there's no need/no solution that will give HiFi outdoors so I was thinking about a wireless speaker - But one that would link up to the Superuniti and Qb to play simultaneously - the SU isn't far from the garden but it would be slightly nicer to have the SU, QB and a garden speaker all at a reasonable volume rather than one cranked up to serve two areas.
adclem posted:
That’s why you need a Naim solution - or a workaround solution using Airplay - otherwise you won’t get all the players in sync.
Posted on: 09 April 2018 by NickSeattle
Digital Out from the SU to an integrated amp with DAC onboard is the way I would do it —volume for outdoor speaker controlled at the new amp.
Nick
Posted on: 09 April 2018 by Innocent Bystander
Bart posted:
It is actually easier to achieve high fidelity sound outside than it is indoors, as room effects are less or even nil: indeed, the best sound I have heard from any hifi system ever was with my own speakers outdoors. However, unless you live miles from anyone, playing at even a half decent level would be inappropriate other than rare occasions...
Damp resistance or weatherproofing is a consideration if the speaker is to be left out for more than a very few hours, depending of course on weather, especially paper based driver cones, but also mdf cabinets and wood veneers etc., all of which can be very susceptible to humidity. If intended to be permanently set up outside you can get speakers designed for the purpose, but otherwise a simple  approach is to put the speaker in a plastic bag: a thin plastic bag over the speaker has quite a negligible effect, yet can be taped up, and even a bag of silica gel drying agent sealed inside with the speakers if you are wary about taking precious hifi speakers outside. If a wireless speaker the bag won’t interfere with the signal.
Posted on: 10 April 2018 by blythe
The bottom line is, I believe, that only Naim wireless speakers (Muso and QB) will integrate into the Naim system.
Posted on: 10 April 2018 by NickSeattle
blythe posted:
A Uniti Qute or better would do, of course.  And if given the choice, I would expect the digital connection to sound noticibly better than Naim’s Party Mode over Ethernet.  I can attest from experience that an analog connection between amps beats Party Mode significantly in my own system.
Nick
Posted on: 10 April 2018 by ChrisSU
NickSeattle posted:
blythe posted:
The OP is already using multiroom between two Naim streamers indoors, so I somehow doubt that he will want to start running cables into his garden! Even if he did, I imagine the three players would probably not play in sync.
ChrisSU posted:
NickSeattle posted:
blythe posted:
I have never found connecting residential speakers, indoors or outdoors, using actual wire to be an exotic solution, but expectations move on, I suppose.
I have never heard a wireless implementation that was not bettered by a wired alternative, sound-wise and for reliability, to my disappointment; though some wireless speakers do impress me with their accomplishments, nonetheless.
For a Naim solution that actually works, I like both your MuSo-in-a-bag, and my deluxe alternative using the Qute and speaker wire.  Even if not wiring back to the SU, Party Mode should get the job done.
Nick
Posted on: 17 April 2018 by NickSeattle
Decision, Adam?
Posted on: 19 April 2018 by adclem
As i say, its for a garden so sound quality is not relevant to the same extent as an indoor system. The environmental noise puts end to that.
Judging from the wise folks who have replied above, a non-Naim speaker cannot be connected so I’ll have to do without, or get a little Qb and move quickly if the weather turns
Posted on: 19 April 2018 by cdboy
If it helps I have Roon enabled which currently I use on my Atom. As a bonus I can activate otherwise redundant Apple Airport express(s) as an end point and then utilise also otherwise redundant HiFi bits to create two extra zones that can access my digital library. Both happen to run outside as well, allowing app control of both the Atom and the outside zones. Most agreeable.
Posted on: 19 April 2018 by ChrisSU
cdboy posted:
For the OP, using Roon’s multiroom instead of Naim’s could be an option. To use it with a Superuniti, though, would need an Airport Express attached by an optical cable, and all streamers to be run over Airplay.
Posted on: 22 April 2018 by Eloise
ChrisSU posted:
If you don’t already have a spare Airport Express, a Raspberry Pi and Allo DigiOne or similar might be a better option.
Posted on: 22 April 2018 by ChrisSU
Eloise posted:
ChrisSU posted:
I don't actually know what an All DigiOne is! But the point I was trying to make is that with Roon multiroom, if one of the endpoints (i.e. an outdoor speaker in this case) has to run over Airplay, then all of them must run on Airplay, otherwise multiroom won't work.
ChrisSU posted:
I though Roon allowed you to use end points such as the Atom and RaspberryPi alongside Airplay endpoints?
You are likely right, I’m just asking to confirm.
Eloise posted:
ChrisSU posted:
You can’t mix them, unfortunately  it has to be either all Roon, or all Airplay.
Posted on: 24 April 2018 by Eloise
ChrisSU posted:
Eloise posted:
ChrisSU posted:
Thanks... always happy to be educated :-)
