4.6 firmware update problems
Posted by: gsr on 11 April 2018
Trying to install new firmware but when I try to install the driver software from this link (http://www.silabs.com/Support%...210x_VCP_Windows.zip), I keep getting the following error message :
"device driver installation wizard was unable to find any drivers designed for your machine"
The computer (PC) is linked to the Uniti 2 by a mini USB cable and the device is on.
Any ideas or suggestions would be much appreciated.
Gordon
Posted on: 11 April 2018 by GraemeH
You need to save the zip to your machine and then ‘Extract’ and run the exe...I know because I did exactly like you yesterday before being rescued!
Good luck,
Posted on: 11 April 2018 by gsr
Thanks Graeme, Working now!
gsr posted:
Knowledge transfer from ‘FinkFan’ & ‘HifiMan’...I was clueless before they intervened!
Glad it’s working.
done the factory reset and have the following fault come up - Fault 61 BridgeCo init fail
Any ideas?
Switch off for a minute then power back on - seems to resolve the issue.
Posted on: 11 April 2018 by Huge
Turn it off, leave a few min then turn on again.  This sometimes works.  Try another reset if you can.
Once again thanks Graeme. Working now!
gsr posted:
