Flatcap XS fascia
Posted by: sihctr on 12 April 2018
Hi all,
I've got a second-hand FlatCap XS, bought several years ago through a dealer. When I got it, I noticed that it had the "bleeding" logo issue, so I got the fascia replaced for free. However I just noticed that there is a small gap between the fascia and the box. It's a couple of mm maximum and you can only notice when looking from close-by.
Anyway, I wanted to ask if this is something I can easily fix on my own (I know how a screwdriver works!
), or if it has to go back to the distributor. Not keen to spend time and money if it's something easily adjustable. I understand that DIY discussions are not permitted on the forum, so a rough "indication" would suffice!
Thanks all in advance!
