upgrade mostly succeeded but shown error in comms in firmware file
Posted by: philipsweetman on 15 April 2018
I have an NDX and a UnitiQute2 and after some fiddling about with drivers (never had a problem with previous upgrades) managed to get both to update. Both report a problem during the Streamer Update saying communication issue with a file "SeDMP3_v14171.73_xxx_Tidal_MR-NP-Compat.bcd". Repeated the install and same thing every time. When rebooted the streamers both report 4.6 firmware and seem to run fine. I am not using Tidal as I prefer spotify if anything and I do not have the input ticked. Not sure what the issue is though and what I should do about it?
Philip
Posted on: 15 April 2018 by David Hendon
Which firmware did you upgrade from? The reason I ask is that if you updated from earlier than 4.4 the update to 4.6 doesn't show Tidal in the list of inputs. I have discussed with Naim and the solution is to now install the 4.4 update and then do 4.6 again.
best
Posted on: 15 April 2018 by philipsweetman
Upgraded from 4.4 but can see the tidal input, just didn't have it selected. so not sure what I am missing and what the error actually was?
Well if you upgraded from 4.4 the I don't know what to suggest.
You could ignore it or you could ring Naim support. But I suggest ignore it....
best
