Mu-so Qb in Bathroom?
Posted by: PuriSoka on 16 April 2018
Looking for good music at my bathroom, Mu-so Qb would be very nice.
Now I am not sure if Mu-so Qb will be damaged (we are 3 person using the bathroom, and we open the window after showering) or not.
What are your experiences?
Posted on: 16 April 2018 by Finkfan
Not a great idea to have anything mains voltage in the bathroom, wherever you are in the world. Get something battery powered instead.
Posted on: 16 April 2018 by PuriSoka
With a professional wiring there this should not be a problem. Battery driven devices provide not that good sound ...
Posted on: 16 April 2018 by wenger2015
It could be electrifying, in more ways then one?...
Posted on: 16 April 2018 by james n
Electricity in bathrooms aside, I'd also be concerned about the longevity of the QB in a high humidity environment.
That's what I want, electrifying musid in my bathroom.
Does Mu-so get damaged so quickly? Humidity will not last a long time after taking a shower  ...
Bathrooms tend to be higher humidity areas. I'm sure it's not going to die quickly but I'd still not recommend using one in a bathroom. I'm thinking a typical UK bathroom here...
I'd ask your dealer or Naim themselves for advice
I think the Swiss bathrooms are kind of simila to the British ones. Naim support does not answer
Posted on: 16 April 2018 by Beachcomber
PuriSoka posted:
I have frequently installed music in bathrooms as I move from house to house.  I would not put a QB or any other amplifier in the bathroom.  While it can be done so that it is electrically safe, you would probably not be able to get at the controls (you are not allowed to put a light switch inside a bathroom, except for a pull-switch type. AIUI).  More importantly I don't think it would do the QB any good.  What I have always done is just put speakers in the bathroom.  Often I put them under the bath (yes, that does alter the sound, but it's just the bathroom, so I'm not trying to get great hifi.  And it is unlikely that I would - bathrooms  generally echo and have all sorts of deleterious effects on the sound).  Under the bath has the benefit of being less affected than other parts of the bathroom by humidity etc.  I would expect that whatever speakers I used, they would die eventually anyway.  Hasn't always happened, but in the house I'm in at the moment I put JBL Control 1 speakers in (great little speakers).  After a few years the rubber round the edge of the cones disintegrated.  Usually, though, the speakers have survived.
Steve
Thank you very much sharing your experiences. I'll have a look at the JBL Control 1
Greg
Posted on: 16 April 2018 by Richard Dane
I wouldn't have any electronic equipment in such a potentially wet and humid environment.  In the Uk it's probably moot as any power outlets are restricted to shaver types.  Of course, in other countries it's rather different.  I do sometimes find it rather worrying to stay in hotels overseas where things like a hairdryer are precariously hung right above sinks and baths.
Your best bet is to either have a proper made-for-purpose waterproof in-ceiling or in-wall or on-wall speaker installed (with amplification electronics usually positioned outside the bathroom), or else keep the Mu-so outside the bathroom and just turn it up a bit.
What I am looking for is a speaker with radio DAB+ or access to internet radio and access to WLAN-NAS controlled by smartphone
Posted on: 16 April 2018 by Eloise
Finkfan posted:
The problems with electrical devices in the bathroom is more the plugging and unplugging.  In the U.K.: it’s technically legal to have a mains socket so long as it’s outside the “wet zones” - 3m from a bath or shower. (Not that I would recommend it in any case).
It all depends the size of your bathroom really.
Unless you want / need multiroom with other Naim devices, I would look at (something like) a Marantz MCR511 (or get a second hand Qute) located outside the bathroom and a pair of EV Evid 3.2 speakers in the bathroom.
Hm. The bathroom size is about 3 x 3 m2
Posted on: 16 April 2018 by ChrisSU
Apart from any safety issues, you might find the sound of a Muso a little overpowering in a bathroom, especially if it has to be placed against a wall, in a room with lots of hard surfaces and not much in the way of upholstery/carpet/curtains.
Posted on: 16 April 2018 by David Hendon
Probably would sound alright with Handel's water music...
Well, I thought about yellow submarine ...
.....Singin' in the Rain......
Posted on: 16 April 2018 by sjbabbey
“Tap turns on the Water”
and of course
”She came in through the bathroom window”
David Hendon posted:
...but maybe not his Music for the Royal Fireworks
Posted on: 16 April 2018 by Daveas
Shower The People  -   If Only the bathroom was a bit bigger.
Posted on: 16 April 2018 by trickydickie
I use one of these, a Panasonic SC-ALL05. They come in black or white
It's battery operated (rechargeable) and waterproof enough that it can be dropped in the bath.  I haven't tried this though!
Sonically it's no Muso QB but perfectly adequate to listen to some tunes whilst having a bath and it's nice and portable if you want to move it around the house.
That's not nearly shocking enough. How about...
Posted on: 23 April 2018 by Artferg20
It’s hardly a Qb, but I use a UE Roll 2 Bluetooth speaker via its auxiliary input connected to a Roon based raspberry Pi that sits outside the bathroom. The sound is pretty decent for a UK bathroom space plus it’s also waterproof with my kids putting the latter to a test.
Perhaps a larger model is worth considering!
Posted on: 24 April 2018 by Claus-Thoegersen
Hi,
I was at a Dynaudio demo last weeke, where they showed their new mu-so type Music line. The 2 smallest unit Music 1 and 3, were as I understand it battery powered. However I would think they have to be charged from time to time.
https://www.dynaudio.com/home-audio/music/music-3
Posted on: 24 April 2018 by PuriSoka
Oh, they look very interesting. How is the sound?
