Unity Star
Posted by: The Pitt on 17 April 2018
Just had a brand new Unity Star all is very well but I find I cannot activate the proximity sensor feature, any ideas?
Posted on: 17 April 2018 by ChrisSU
I wasn’t aware that it was possible to activate/deactivate it, mine just works. Do you mean on the Star itself, or the remote, or both?
Posted on: 18 April 2018 by The Pitt
Hi, Yes on the Star screen, its supposed to come on when you approach i'm sure its just set up at the factory?
Posted on: 18 April 2018 by TallGuy
As Chrissu says it should just work. If putting your hand in front of the display doesn’t activate it you either have a fault or there’s no alternative screen for it to show. To rule out the latter select internet radio, “play” a station - you should see the station logo. Bring your hand to a few inches from the display and it should switch to show bit rate and perhaps track playing info. If not you have a fault.
Thanks for that, yes it does work as described, I thought it activated the screen when you approach it like walk in the room, not a few inches away .
Thanks to you both, my mind is now at rest.
The Pitt posted:
I think mine works from around 18-24 inches away (sorry, I’m on holiday so not able to try it out for a few days); it’s more than a few inches. I’ve found my cats can flip it when they walk past - can be very distracting
Now its stopped responding, I had the internet radio station artwork, waved my hand now, no change, still the bigger image .
It worked an hour ago !
