NDX Display
Posted by: nocker on 19 April 2018
Is there any way to turn the brightness up/down on the NDX display?
Posted on: 19 April 2018 by Pcd
Never seen that option on my NDX I think its just on or off.
Posted on: 19 April 2018 by ChrisSU
It’s best to have the screen off as much as possible, as they are prone to failure if kept on.
Posted on: 19 April 2018 by Adam Zielinski
No - it’s not possible
It can be switched off after a pre-set amount of time e.g. 30 secods
Posted on: 23 April 2018 by nocker
Thank you, my screen must have died then as it is very dull, I can’t read anything on it.
Posted on: 23 April 2018 by NickSeattle
Many have reported this issue; it happened to mine.  Fixed under warranty. All I had to pay was $50 (I think) to my dealer for shipping.
Inconvenient, but well handled by Naim.
Nick
Posted on: 23 April 2018 by David Hendon
nocker posted:
As you are in UK if you take it back to the dealer who sold it to you and it's under warranty, I don't think you have to pay for the shipping either.
best
