Nova refuses to play Tidal - suddenly
Posted by: hifinewbie on 19 April 2018
Hello Experts
After about 2 weeks my Nova refuses to play tidal, and i changed password (does not have special characters), reinstalled app, tried the app from 2 different devices and nothing works.
Any help?
Posted on: 19 April 2018 by Mercky
hifinewbie posted:
Hello Experts
Any help?
Have you tried logging in to the desk top version on a computer and see if your log-in and user name are working? I suspect your password and user name are not matched
Posted on: 19 April 2018 by hifinewbie
i will try that, but i have tried 2 different TIDAL user ids and both have same problem.
Posted on: 23 April 2018 by Artferg20
I would pull the plug from the mains, plug back in after 20 seconds or so. Then do a factory reset using the remote handset.
Press the home button
Go to settings
Factory reset. That should solve it.
Posted on: 23 April 2018 by hifinewbie
Artferg20 posted:
Go to settings
Thanks for the suggestion, by pulling the plug and restarting the system did the trick!
