Naim App
Posted by: Rjt36 on 21 April 2018
Hello all, My Naim app is doing strange things: when I switch from UPnP to Spotify, it continues to show my Synology nas drive server, as opposed to allowing me to launch Spotify?! But when I go from iRadio or CD, to Spotify, it launches Spotify immediately. Any ideas please?
Posted on: 22 April 2018 by HiFiman
Similar things happen to me when running Naim App on android, only fix I found is to close the app and start again.
On Apple devices it seems okay switching between sources.
Posted on: 22 April 2018 by ChrisSU
I’ve found a similar issue on the iOS app when trying to switch between Tidal and UPnP inputs.
Posted on: 22 April 2018 by David Stewart
I've had similar issues with the Android version and Tidal. Quite often it can be fixed by switching from UPnP to the front panel or USB input and then to Tidal or vice versa. Not always though, then it requires the app to be closed down and opened again.
Posted on: 22 April 2018 by Japtimscarlet
I get the above fault constantly!
It's very frustrating...
Posted on: 22 April 2018 by David Hendon
You should all report it using the feedback option in the app, if you haven't already.....
best
Posted on: 22 April 2018 by Rjt36
Thanks all - ‘good’ to know it’s not just me ????
